Question about Kidde Pe120 Photoelectric Smoke Alarms 6-nib
How to open access door for kidde pe 120 smoke alarm
oldnovii
  • 667 Answers
SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: my kidde smoke and carbon monoxide alarm keeps
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Posted on Aug 05, 2009
szanti
  • 36 Answers
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Posted on Sep 28, 2009
  • 13 Answers
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Posted on Mar 23, 2010
  • 13 Answers
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
Has anyone ever had a solid alarm for hours with a Kidde Smoke alarm?
I have 5 Kidde alarms and never had that. They are supposed to be replaced every 6 years.
Kidde service is good, they will replace it.
Oct 28, 2015 | Home
Open brooks smoke alarm to change battery
Hi Robin
Usually push in (up) & turn
Feel it as you turn
.....then remove from other half.
Have 9v battery handy for replacement.
Mar 05, 2015 | Brooks Kidde 120 VAC Photoelectric Smoke...
What is the problem when red light blinks but there is no green light
Check the Kidde website for the manual for your model to get specific info...I'm sure it's probably an error indication, but without the model number it's hard to look up.
Oct 15, 2014 | Kidde 120-Volt Front Load Battery Smoke...
Firex 120-1182 smoke alarm
on amazon you can find it easily. take a look here
Amazon com Firex 120 1182 . cheers
Feb 12, 2012 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde # 1276 chirps indicating low battery. Battery replaced and chirping continues. Why?
Don't know for sure, but if your smoke detector is more than 5 years old, than you have to purchase new one (that's their average lifetime). Take a look on amazon: Amazon com smoke alarm. I hope I have helped. Cheers
Aug 08, 2011 | Kidde 120-Volt Front Load Battery Smoke...
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
I have a Kidde combo smoke/carbon monoxide alarm and when my window air conditioner goes on the alarm goes off?
I assume your alarm is hard wired which should have its own circuit especially if there are any fluorescent lights on the same circuit.
Jul 06, 2011 | Kidde 120-Volt Front Load Battery Smoke...
My Kidde Sillouette won't stop nuissance beeps. I originally set it off by opening oven door and the manual is no help...
If the detector is within 15-20' ' of you oven, it's going to alarm every time you open the oven door, when the range is on. Cleaning and moving the detector is your only solution. Not sure your detector has one, but if it has a reset button, press it for 5 seconds and release it. That should stop the chirping.
Mar 06, 2011 | Kidde Silhouette AC Hardwire Smoke Alarm...
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Jun 03, 2010 | Kidde PE120 Hardwire with Battery Backup...
My kidde smoke and carbon monoxide alarm keeps beeping and saying low battery and i don't have a manual how do i open it so i can change the battery?
Aug 05, 2009 | Kidde i12040 Hardwire Smoke Alarm with...
Kidde Pe120  Photoelectric  Smoke  Alarms  6-nib Logo
73 people viewed this question
Top Kidde Home Security Experts
richie46
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
