Question about Baby Lock Eclipse Serger
Feed dogs on serger don't advance
I own a Baby Lock serger, model#BLSE200(N) and I really haven't used it for a long time but when I uncovered it to use today...it seems like the feed dogs won't advance the fabric. I have it threaded correctly and that's working, but the fabric doesn't advance on it's own. If I pull it thru, it works but not alone. The last time it was used was by my daughter about 3 yrs ago. I have tried adjusting tension buttons but nothing is solving the problem. Any advice??
Thanks!
  • buttonpr Mar 19, 2009
    I just bought a used Babylock 5260D and I have it threaded correctly but the feed dog will not advance the fabric. This one has been in storage for several years as well. Sounds like we have the same problem.
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Posted on Jun 30, 2009
  • 107 Answers
* Fabric will not feed into machine.....
1. ls the presserf oot down?
2. Are the knife blades sharp?
3. Are the knife blades clean of lint?
4. ls the presser foot properly adjusted?
5. Are the feed dogs and presser foot free of lint?
6. Are the knives properly set and is the upper knife against the lower knife?
7. ls stitch length set properly?
Posted on Dec 11, 2009
  • Val
    Val Dec 11, 2009
    You might take a look on eBay item 150373256653
  • 3 Answers
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance bu a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. In PA might cost $150 to fix. $79 in parts; $80 in labor (2012 prices)
Posted on Dec 21, 2012
INSTRUCTION MANUEL
I have a friends Baby lock BL 5180. She could not get it to work so I brought it home. I thought it was probably just the way it was threaded so I rethreaded the machine and noticed that the feed dogs are not moving. The machine works but will not pull the material into the machine.
Oct 29, 2013 | Baby Lock Eclipse Serger
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Baby Lock Serger 5360ED
when the feed dogs aren't moving like they should, then the machine needs to be serviced to see why,
May 29, 2012 | Baby Lock Sewing Machines
My baby lock 5180 isn't pulling my material through to serge
I have the same problem. The feed dogs are not moving.
Jan 12, 2010 | Baby Lock Eclipse Serger
We were just given a babylock serger and the fabric won't advance. The dogs don't seem to be moving.
Depends on the model but some machines have a problem that the feed regulator cam has become loose (2 set screws) and will not advance the material. A good Babylock dealer will be able to diagnose quick.
Jul 20, 2009 | Baby Lock Sewing Machines
Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Mar 19, 2009 | Singer Quantum XL-5000 Computerized Sewing...
What does the differential feed do?
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Mar 18, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
1,166 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
