Question about Saws
Reciprocating saw will not start
HDC Homier distributing, Heavy Duty Reciprocating Saw, 120 Volts, 500 Watts, 2000 SPM speed
  • Saws Master
  • 1,803 Answers
Powercable problem to measure , carbonbrushes remove and watch if no autostop protection (a little black pin comes out the front of the brush you must remove to see this if its happend ) so yes replace the brush do not remove the pin .
or a contact to the switch or one of 4 points of the electricfield is defect measure both fieldcoils measure between the form carbon brush to carbonbrush through the anchor for an broken collector you see sometimes visible damage of the collectors on it if one stands on a brush it will not start and if it starts by a litle turn by hand of the air-vin of the anchor it may uses or a humming noise and hot or draws sparks and become in any case a hot machine drawing too much power
Posted on Mar 30, 2016
  • 313 Answers
SOURCE: Dewalt DW303 reciprocating saw
go to www.dewaltservicenet.com look for the icon find it now.enter the model # of the tool & search
Posted on Sep 19, 2008
SOURCE: Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Posted on Apr 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: labeled diagram of reciprocating saw
go to Milwaukeetool.com and type in your model number and also you will need your serial number and you can download a wiring diagram and also a breakdown and owners manual for this tool. If I have helped you with your request would you please rate this response accordingly and thank you.
Posted on Dec 02, 2009
Blade doesn't move (reciprocate)
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Oct 31, 2012 | Dewalt DW303 Heavy Duty 65 Amp...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do I remove a broken blade from a dw304 saw??
Unloosen the blade and You could try holding a strong magnet against a screwdriver and touch the blade of the screwdriver to the broken blade and pull it out.
Mar 16, 2011 | Heavy Duty DeWALT DW304PK DW304P HeavyDuty...
Is the Dewalt dw310 multi purpose saw available in 110 volts
  • Help Instructions, Repair Guides, Manuals & Troubleshooting sacore:green.gif Dewalt DW310K Heavy Duty Reciprocating Saw Kit... Is the Dewalt dw310 multi purpose saw available in 110 volts - posted in Reciprocating Saws ...
    www.fixya.com/troubleshoot
  • Jan 14, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
    Orbital or Straight Comparison
    An orbital reciprocating saw moves in a more elliptical or oval shape rather than just up and down. This makes it more aggressive and gives it a faster cut. Straight reciprocating saws move on a single plane, back and forth.
    Aug 27, 2008 | Makita Orbital Reciprocating Saw 2500 Spm,...
    Cordless or cord saw Comparison
    Cordless tools lose power as the battery drains, while corded tools deliver reliable, consistent performance with unlimited run time. Corded reciprocating saws range from less than 5 amps to 15 amps or more, with more than 10 amps providing optimal power for heavy-duty commercial use.
    Aug 27, 2008 | Hitachi 11A Motor, Reciprocating Saw,...
    Saws Logo
    599 people viewed this question
    Top Saws Experts
    Tom Chichester
    ray gallant
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Saw Expert? Answer questions, earn points and help others
