Question about GE Kitchen Ranges
Troubleshoot GE Range, model #JBS 07 H2 WW
All Burners not getting hot
Krazytech
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
fridgetech
  • 473 Answers
SOURCE: General Electric electric range
Give me the complete model # from the sticker on the oven so I can look into this for you.
Posted on Nov 11, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Burners on a GE Spectra JGBP30 Gas range don't ignite
Try this link and download PDF has numbers and answers
http://lib.store.yahoo.net/lib/usappliance/JGBP35manual.pdf
Posted on Jan 31, 2009
My jbs 07 m1bb, the oven temp runs away,overheats,at any setting
More than a single answer- there is a thermistor or thermocouple that monitors the oven temp. and this can fail.
The electronics that do the regulation using input from one of the mentioned devices can fail.
Any service tech should be able to answer quickly but one needs to be on-site to determine which is at fault.
Dec 23, 2014 | GE Kitchen Ranges
GE Model JBS 260 V2AD Oven temperature flucuates 25 degrees up and down while in use.
Hello, Thank You for using FixYa. I will be helping you today.This is normal..When you set the oven to say 350 that means the avarage cooking temp is 350.There is nothing wrong.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | GE JBS26 QuickClean Electric Kitchen Range
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Nov 11, 2007 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
