Question about Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
I've just received a new thermostat for my wine cooler but cannot remove the old one as the thermocouple cannot be pulled out. How is this removed and/or how do I get to where-ever it might be attached?
Thanks for the help.
ronolivia@att.net
My danby dwc172bl wont get cool what to do
Posted on Feb 17, 2010
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Posted on Jan 20, 2009
Want to install a new thermostat. where does it go in a DWC612BLP cooler
Hey, man go there you have the plan for your equipment
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Feb 20, 2014 | Danby DWC612BLP Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Wine fridge thermostat
No pictures, the new one goes in the same as the old one comes out. You have 2 screws on the bottom of the evaporator that holds the sensor in place. Then the sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.
Oct 02, 2009 | U-Line 75WC Wine Cooler
Wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Jun 17, 2009 | Danby DWC283BLS Wine Cooler
Temperature control non-functional
I found a repairman who knows how to replace failed thermostats using other than OEM equipment.
WSN
Jan 17, 2009 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler stopped cooling
I have seen this before. Get the thermostat off and put it's 2 wires together just to SEE if the wine cooler comes on. Be careful not to let it bite ya or ground against the cabinet. If it runs then thermostat replacement needed, now how simple is that?
Dec 23, 2008 | Refrigerators
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Danby Silhouette DWC512BL Wine Cooler Logo
696 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
