Question about Nokia Tablets & eReaders
How do I perform a hard reset on my Xtreme 7 in tablet?
I tried pushing the reset button, but that did nothing except turn my tablet off.
3 Suggested Answers
TechyDrood
  • 2072 Answers
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
Posted on Dec 04, 2012
TechyDrood
  • 2072 Answers
SOURCE: tablet wont boot into anything but screen with horizontal lines..just got it today and charged battery and now i get nothing?
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
  • Make sure the tablet is powered off
  • Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
  • There should be an option to factory reset or something to that affect
Posted on Dec 08, 2012
My Xtreme tablet when turn on its just booting.I turn it on and off still doing the same thing
If you can, perform a hard reset. Sounds possibly like a hardware error though. After a reset , should the issue still be present that would probably confirm it
Jun 20, 2015 | Tablets & eReaders
How do I hard reset an Xtreme Play Tab Dual-Core 4GB Google Android 4.4 7 Touchscreen Wifi Tablet
turn your tablet off. Press and hold the volume up, volume down and then press the power button. Do not release until the recovery menu comes on then choose restore if that dosent work ...turn tablet off/hold the volume down button and the home button and power it on
May 08, 2015 | Tablets & eReaders
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
How to hard reset xtreme tablet
Hi Emani, to complete hard resetting of your Xtreme tablet, you have to hold the power button on / off along with volume button up / down simultaneously. Then only you get a menu in which you have to select the option for hard reset. Then, your tablet will complete get hard reset and go back to how you bought it.
Dec 13, 2014 | Tablets & eReaders
I cannot unlock my tablet from the touch screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Mar 08, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Forgotten passcode can i do a factor reset or a hard reset
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 29, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
MY touch screen wont work for some reason so now it wont work
I suggest you to perform a hard reset as sometimes this may be due to a software glitches chances are rare though but still you can give it try. Else you need to replace the touch panel of your table which I suggest you should not do on your own rather take it to a hardware shop. Hard reset in most of the android tablets is usually performed by turning off the tab and pressing power button while holding the volume down key.
Sep 26, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Tablets & eReaders Logo
2,939 people viewed this question
Top Nokia Tablets & eReaders Experts
mukhtar21 shaikh
mukhtar21 shaikh
ray gallant
Are you a Nokia Tablet and eReader Expert? Answer questions, earn points and help others
