Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 While moving our tv, the screens were damaged, please let me know where the best place to purchase them would be. Also how difficult are they to install. Thankyou in advance!!
    New Friend:
  • 129 Answers
This are the part #s for the screens 23430784 fresnel 23430783 lenticuclar . the screen protector just measure the size and go to home depot and they can cut the plexiglass for you. to get the parts go to this link .http://www.vancebaldwin.com/
Posted on Jun 24, 2007
  • Luis Amado Jun 29, 2007
    Any luck? let me know if you need more help
I have a 50A60 toshiba 50 in rear projection tv I have a green screen no pic but I have sound
Is there a cable or Satellite box hooked up for signal?
How and where is signal connected to the TV?
Dec 13, 2012 | Toshiba 50A60 50" Rear Projection...
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
Good morning, I need to clean inside of my Toshiba 50A60 model tv screen, I do you remove screen?
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Sep 30, 2009 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
Cracked frame on brand new sony bravia 52" HD LCD TV
I would definetly call Sony and if it is something you can't live with return it, but remember impact damage voids the warranty, in other words if you were to drop the tv trying to return it the warranty is void. As much as you paid for that tv it should be cosmeticly a functionaly perfect. Let me know if I can provide further assistance and please rate this solution. Lone99star
Jan 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Jan 08, 2009 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Mar 08, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
