Question about Reddy Heater-40,000 BTU Kerosene w/T'stat
Reddy heater 40000 btu heater hums when you plug it in then stop
It doesn't light , and the fan doesn,t go on
  • 232 Answers
Check the air pump. If you are lucky the rotor is busted. If not, see if the fan spins freely with no binding. If so, the starter relay is bad, if equipped. Some heaters have external relays, others have internal relays and are not serviceable. Could also be a bad bearing. Could also be - someone sat on the heater or dropped something on it, or it fell out of the truck and the sheet metal is squashed and is against the fan blade.
Posted on Feb 15, 2009
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Hello i havent Used my ready heater 60000 btu since last winter. It was working fine when i unpluged and emptied when i plug it up i hear a hum and nothing else no blower or anything....could ude...
The fan motor is setup...
Tear it part and get some WD-40 worked into the motor at the shaft end... then when you get it spinning freely... get some light motor oil worked into the bearing...
Works best if you can tip the heater back so the WD-40 and oil naturally run back into the motor...
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
U must get a low pressure guage at auto zone and adpt it to fit into the left hand test port. Fire the heater and adj. guage to 3-4 psi the needel should be at a fast sweep low sweep of 3 and the higest
4. see what happen and let me know ps. that is 8 th inch pipe thread in the test port
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Kerosene forced air heater will not light, only hums.
Your problem may be as simple as the vanes of the rotor stuck to the pump body, or a rats nest binding the fan blade, or the starter relay being defective (if equipped ) . On the other hand, the bearings in the motor could be frozen up. The motor is not servicable and must be replaced. Start by disassembling the air pump, remove the vanes & rotor, then attempt to start the motor. If it still hums, then you have motor or relay problems.
If the vanes were stuck, clean it up, reassemble (no oil) , set the pump pressure.
Oct 29, 2008 | Reddy Heating & Cooling
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-40,000 BTU Kerosene w/T'stat Logo
164 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
