Question about Coleman 7990-319p Evcon Gas Furnace Control Board
My coleman evcon model # DGAT075BDE will not ignight
Trouble shooting blinks one time having problem ignighting
5 Suggested Answers
  • 306 Answers
SOURCE: Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Posted on Nov 30, 2008
SOURCE: Have a Evcon Coleman Furnace shows three green
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Posted on Oct 04, 2010
  • 24 Answers
SOURCE: HEATER DOES NOT IGNIGHT FAN
check blinhing light on pc board will read on door panel.
Posted on Dec 26, 2010
  • 114 Answers
SOURCE: we have a coleman evcon
Explain the problem further as I do not understand the problem(s)
Posted on Aug 03, 2011
Sony kp44px3u rear projector blinks 11 times red led then Off 3 second then 11 times off 3 second what dose this mean
your problem is most likely on the deflection power supply b Board a diode possibly d303 or mcz3001b Smps control IC . it will require some trouble shooting . and you will need a digital multi meter and schematics to trouble shoot the power supply further
Feb 02, 2015 | Sony Televison & Video
How to trouble shoot ignighter for pool heater?
disconnect it should ohm out at about 78 ohms at 70 degrees if open no good or shorted no good replace if voltage to gas valve when it should be firing bad ignitor
May 16, 2014 | Raypak Free Hydraulic Lift Gate Delivery -...
Indicator blicks 3 times replaced combustion air switch but did not resolve problem. what do i do now?
there should be a diagnostic code that will tell you what 3 blinks mean for that model. look on door inside cover. tell me EXACTLY what it does at start up. small draft motor comes on? you see a glow from hot surface ignighter? gas comes on? flame on? it should run in this order.
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Stats ignights and goes out
Other similar questions on this site state that this is a problem with the water flow sensor. Although if that is the problem the flame would likely light for only about one second before going out. The water flow sensor fix discussed does not require any new parts. This YouTube video will talk you though it. Good luck.
Apr 02, 2013 | Coleman Hot Water On Demand
7 blinking lights
How many times do the light blinks at a time of switch on? Count it carefully. These blinking are fault indications. Check this site for more details about Panasonic blinking codes. Just search by it with the model number of your TV, to its search box.
Feb 01, 2013 | Panasonic Televison & Video
My sony kp-65ws510 blinks a red light on standby
possible problem is on the G board which is the power supply suspect D6301 leaky causing this
there are also other possabilitys the D board there could be convergence circuit failure of hv circuit failure will need some trouble shooting to localize area of repairs needed
the amount of blinks once you have started it up do help to lead to a area for trouble shooting
Jun 05, 2011 | Televison & Video
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Coleman 7990-319p Evcon Gas Furnace Control Board Logo
125 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
