Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
No sound comming from audio volume
My speakers don.t work at aqll. my computer is brand new still 2 years old.how can i fix the problem. i need the e machine manafacture number.
    Scholar:
  • 77 Answers
First check if you have the speakers pin (green) connected in tothe proper green socket on the back of the computer.
If yes, then right click on the sound / speaker icon that is near to your clock on the right bottom, and click "Adjust audio properties"
Now click the sounds tab in the audio properties.
Select any sound from the list under program events, and click the play button near the browse button. It should play a sound.
If you are not able to hear any sound BUT the play icon changes to the stop icon for a few  moments, it means the sounds play alright but something is wrong with the speakers or the connections.
HTH,
Deboo
Posted on Jan 18, 2009
Old Altec Lansing (no model number on them but they're at least 10 years old) speakers won't work on new Dell Optiplex desktop. They still work on the old Dell Dimension they were on and work on a Del
I have a similar set of Boston Acoustics speakers, which work fine for my tower.
I find it hard to believe that they would just fail outright, and also that (unless you bought an upgraded sound system) you would have digital-only for your audio.
I would recommend to check the basics first.
  1. Check the speakers on another device. Mp3 player will work fine.
  2. check the sound card on your computer (use a set of headphones or another speaker set).
  3. If you find they weren't plugged in, powered on, etc. resolve that. Usually the power plugs are black, and only fit in one spot. The audio cable to plug into the computer is similar to a headphones jack (3.5mm). On most computers the audio output (speakers) port is colored green.
  4. If none of these get you fixed, go into the control panel and click the sounds icon. From there you can view your volume levels (is the sound muted?), view your playback device (it might have a hardware problem, or be disabled), and test the settings.
  5. If you are still stuck after this please also post your version of windows, and the make/model of your computer. If you know it, the type of audio device you are using would also be helpful. (if it's a Dell standard device or perhaps an upgraded Creative or other brand device + model #)
Thanks for asking, and Good Luck!
Dec 16, 2011 | Altec Lansing M604 Computer Speakers
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Jun 29, 2011 | Creative Labs Inspire T3030 Computer...
My packard bell is about seven years old and was fine until i had it fixed recently and was told that i would need to buy new speakers that could plug into the back of the computer as I needed a new...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Packard Bell (030069) Sound Card
I was given the LS11 speakers and have connected them to my computer. However when I click on the volume icon in the tool bar to ajust the volume it does not work.
also
hope this helps
don
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
No sound on computer, was using external in usb, now that doesn't work either.It is a four year old acer computer.
also
hope this helps
don
Mar 05, 2011 | Acer (54.AA806.001) Sound Card
We have default buildin sound card on HP brand PC. i setup windows recently, from then sound device not work. show now sound
also
hope this helps
don
Feb 24, 2011 | HP (400745-001) Sound Card
My speakers are plugged in, the green light is on, but i accidentaly deleted my speakers on my computer and now they dont work. it tells me that there is a new device found but then it says you need a disc...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 22, 2011 | Logitech LS11 2 Speakers
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Speakers not working
do i need a disk to dwnload these to work on my computer
Aug 09, 2008 | Boston Acoustics BA735 Computer Speakers
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
