Question about Panasonic CT-2789VYD 27" TV
Aim 24cm tv remote is missing, and it has been blocked or stalled on menu.
How to unlock child lock for aim tv set model :atv54z
universal remote code for atv54z is 023. Put the tv on with the remote then go into the menu and disable the childlock function
Dec 21, 2013 | Televison & Video
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
I need to know how is the code of OLEVIA MODEL 237-T12..., i need to put that code in my control remote..!!! thank you
if you have a universal remote just check if your tv is listed in the manufacture menu.if it does look for the code beside your tv brand.it could have more than one code so you have to try all of them.if you find it then first turn on the tv manually. you press down the code search on the remote it will stay light release the code search button.press and release the tv button on the remote.enter the code found on the remote chart that is pertaining to your tv by entering it on the remote manually. aim the remote on the tv push the the on off button try this with all the codes untill your tv cut off. if your tv does not appear on the remote list use the manual code search.which is.. first turn on your tv manually press and hold the code search button until the indicator light illuminates.trhen you release it.press the tv button on the remote.the indicator light will blink and stays on.aim the remote on the tv and press the on and off button continously until your tv turns off you have to do this up to 200 hundred times continouslly.when your tv switch off press enter to store your code.
good luck/
Mar 04, 2011 | Televison & Video
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
Recently purchased a rca tv model F35317, parental code from previous owener locked need to bypass
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Hope this helps you out. Thanks
Jan 03, 2011 | RCA F35317 35" TV
The TV is blocking certain channels and I don't know the code to unblock it.
Parental Controls.
Jan 03, 2011 | RCA TruFlat 27F520T 27" TV
Just bought a used older model rca tv parental controls locked. any master codes to bypass parental control
Parental Controls.
Jan 03, 2011 | RCA 27V520T 27" TV
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Resetting lamp life after changing lamp
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps, best wishes.
Apr 23, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a 32" rca tv. model #27vsi3t that I accidentally went to the main menu and locked the tv so that I can't turn it on from the television . how do I unlock it.
MENU button on the television simultaneously for 3 seconds. Parental
Parental Controls.
Quick tip: Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Sep 09, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Panasonic CT-2789VYD 27" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
