Question about Roper REX4634KQ Electric Dryer
I want to disconnect the buzzer sound on my dryer
Everytime the dryer is finished, it makes this annoying buzzing sound for about 3 seconds and it wakes up my new baby. I want to disconnect the buzzer if it is possible. How do I do this?
  • 198 Answers
First of all if you can remove the back of the console to expose the timer and switches, there is usually a small block with 2 wires to it, and it has no knob connected, this is usually the alarm buzzer, remove 1 wire and tape it off,then try the dryer if no alarm wala.
Posted on Jan 19, 2009
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
How do I turn off the alarm on the dryer so that it just stops without repeatedly buzzing at the end of the cycle?
hello trishwadman, i'm sure there are a lot of people who would love to disable this feature. The good news is that you can. You will have to access the inside of the control panel.
http://www.youtube.com/watch?v=xGIG8Wo5-N4 This video will show you how, but you probably can do it on your on. Just pull the knobs off first.
Next you will need to locate the buzzer.
https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180877.pdf If you look at this parts diagram for the dryer. Scroll down to page number 3 and look at PART number 3. That is your buzzer. All you have to do is disconnect one of the wires from the buzzer itself (should have 2 wires connected), and tape the end of the connection (the metal part) with electrical tape. You do not want the loose wire contacting the console or rattling inside of it while the dryer is on. That's all you have to do. No more deafening buzzing at the end of the cycle.
I hope this works, and I'm going to go do mine when I'm finished with this. My wife will be very happy if I do.
Hope this is helpful to you.
Thanks,
Mike
Jul 22, 2011 | Whirlpool LER5636P Electric Dryer
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    My dryer making buzzing sound
    There can be many reasons why your dryer2_bing.gif will not turn...
    This tip that I wrote will help you to figure out what is happening...
    Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
    http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
    Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
    http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
    heatman101
    Jun 02, 2010 | General Electric DVLR223EGWW Dryer
    I want to turn off or disconnect the "finished cycle Buzzer".
    That buzzer can easily be defeated so that baby won't wake up or paw paw! LOL! It is located near the control up top. A small black box with 2 wires going to it.
    Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
    Turning the beep off?
    1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    BUZZER
    make sure timer is completely off. if it still buzzes you will need a new timer or disconnect the buzzer which is cheaper
    Dec 12, 2007 | Kenmore 659 Electric Dryer
    Roper REX4634KQ Electric Dryer Logo
    260 people viewed this question
    Top Roper Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Roper Dryer Expert? Answer questions, earn points and help others
