Question about Westpoint TV-201 Microwave Oven
Sparking/growling NEW microwave
My new Sharp R-2130JS Stainless Steel 1200 Watts Microwave was installed yesterday and worked fine. This morning it began growling and sparking. HELP!
    Problem Solver:
  • 40 Answers
Don't use it! Unplug it and take it back to the dealer-sounds like a loose wire or short.
Posted on Jun 24, 2007
SOURCE:
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Sharp R408LS keeps sparking after minimal use. This is our 3rd one. This is mounted on an inside cabintet.
The magnetron is arcing in the interior and will eventually burn out. Check the inside for bare metal or food particals, if okay! the magnetron is breaking down and will eventually go.
Apr 21, 2012 | Sharp R408LS Stainless Steel 1100 Watts...
Microwave KB-6024MS does not heat.
This indicates three parts that can be the culprit, the magnetron "common problem" or the high voltage capacitor or diode, all three work together to heat food. Depending on the nature of the repair will determine the price for parts and labor and may approach the cost of a new one.
Feb 28, 2011 | Sharp KB-6015KS Stainless Steel 1000 Watts...
Our microwave oven was heating fine yesterday and now it runs, but is not heating. any help would be appreciated.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/'/'
Dec 26, 2010 | Thermador MCES Stainless Steel 1000 Watts...
How to replace hv diode for gt4175sts microwave
you must !!!!!!!!!! discharge the capacitor first or it will kill you !!!!!!!!! use a discharge wand then cut out old diode and resolder new one ..
ps tell me why are you replacing the power diode in 15 yrs working with microwaves ibe never seen one blow
Dec 02, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
R-1214 Stainless Steel 1100 Watts Microwave Oven: turns on buts starts sparking in a few seconds. ...
what's sparking... is it by the Magnatron window... or the carousel?...
If there is a carousel... take it out...
if its by the magnatron window,,, then...houston... we have a problem...
might be contamination... and that may require opening up the unit... sorry...
hopefully it's only something floating around in there that's causing the arc...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | Sharp R-1214 Microwave Oven
No heat coming from microwave
Microwave Oven Basic Troubleshooting Tips
heatman101
hghg
Mar 03, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
Replacing inverter board for my sharp R-2130JS microwave
I do not know how to specifically replace the "inverter board" in this model. On most microwaves I've repaired, though, the hardest part is getting them dismounted from the wall if they are rangehood models. I suspect that the inverter board is held onto the chassis with two phillips screws, and all the connections thereto are modular and therefore easily disconnectable and swapped out. The great majority of times, manuafactureres do NOT put multiple connectors of the same pin count and oriention on a circuit board. Give it a go.
Feb 27, 2009 | Sharp R-2130JS Stainless Steel 1200 Watts...
Microwave Ovens Logo
114 people viewed this question
Top Westpoint Microwave Ovens Experts
William Miller
William Miller
ray gallant
ray gallant
Tom Chichester
Are you a Westpoint Microwave Oven Expert? Answer questions, earn points and help others
