Question about Sewing Machines
Serger Hand wheel and Machine will not Work
I have two of the same machines that have limited use. In the past three days I have put 5 hours on each one and now neither one will work and they both have the same bound up symptoms
  • 5 more comments
  • sirchin1 Jan 19, 2009
    I have 30 years of sewing experience, it is not a thread alignment problem, or something simple as thread under the plate. The machine runs fine and then it gets harder and harder as you begin to stitch for the machine to start up and the turn wheel gets stiffer and stiffer until it is bound tight and nothing moves. Leave it for a week and it starts and turns fine and then after 10 minutes of sewing the same thing happens and renders the machine useless.
    Motors seem to work fine on both machines, when I remove the belt, they spin freely, the earthing and fuse conductor can you tell me where they woild be and how do I check? Thanks, this seems like real help.
    I doubt it has to do with the motor as when you turn it over by hand it still siezes.
    These machines are oiled continually when in use and they are right near a sunlite window. Are these answers for real?
  • sirchin1 Jan 20, 2009
    The machines have been all cleaned out completely. This is not lint and debris problem
    The motors work completely fine.
    The condition exists even when you turn the handwheel so that eliminates the solution that its the motor.
  • 19,396 Answers
Looks like this is a mechanical issue.
I don't know if this can help , but link below is showing full disassembly, so that you can get help in finding missing or badly assembled parts.
Parts of the Serger: Handwheel, Motor, & Needles ..
Posted on Jan 23, 2009
  • 8,197 Answers
What sounds like happened is that dust and grime from thread and material got in the housing. You need to open the machine up to clean it out. Get rid of the lint and thread from in the machine. Then oil the gears.
Good Luck
Posted on Jan 19, 2009
  • Jyackle5
    Jyackle5 Jan 20, 2009
    If you crank by hand and it still bindes up sounds like the gars are binding or the shaft that the gears are on is bent.
  • Jyackle5
    I did not say the motor I am talking about the gears and the shaft the gears are on.
    Brigadier General:
  • 8,619 Answers
Hi
These are required to be oiled at the points provided. After that put them for at least two hours where direct sun light is shoned on them. After that you need to clean these with some rough cloth or cotton. Then these will again ready for service.
Thanks
rylee
    Genius:
  • 1,913 Answers
Check your power supply earthing andmotor properly work.alos check fuse conductormay be it is gone.
  • kishor khatri
    kishor khatri Jan 24, 2009
    put oil in all parts.ten if problem remains it need to take service shop .
  • 11,896 Answers
What are the bounding symptoms? Are spools spinning straighly aligned? Also check inside the thread feeding tubes to make sure they are not bent or broken or frayed thread stuck inside will also cause binding and bunching
  • Nate Stansfield
    Nate Stansfield Jan 20, 2009
    Check the cam gear and clutch plate. While moving by hand with cover off, see if gears are getting stuck. check the arm tracks.
    Other possible problems:
    feed dog timing
    the bobbin case tension
    Adjust & clean the bobbin winder release knob
    pendulum timing
    Adjust the hook timing
    Adjust the needle clearance
    Adjust the needle bar height
    Adjust the feed dog height
    Adjust and Balance
    the upper & lower tensions
    Adjust the belt
    Without personally looking at the machine, it is hard to determine. All the steps above are the same steps a repair shop would follow. I will try to help you the best I can to avoid the costly repairs. Let me know how it goes or if you need any more suggestions.
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    SOUNDS LIKE THE GEARS ARE BINDING UP
    Sergeant:
  • 221 Answers
The motor needs to be replaced .just get it replaced to make it work properly.as the current which motor is getting that could also be the problem.if its getting low voltage motor will not spin as per its regular speed and create this problem
thanks.
Posted on Jan 20, 2009
I bought a second hand babylock eclipse serger, the pproblem is the width sticth adjusment is stack, how do I slove it.
Just guessing the machine may need cleaning and oiling. Consult the owner's manual. Sergers usually require frequent oiling (more than sewing machines) because of the speed and complexity of moving parts in a serger. Apply 1-2 drops of fresh, good quality oil for your machine--some brands use a specific weight oil.
If in doubt, take it for service. It could probably use a very good check-up by a professional anyway. At least then you will be starting out with a tuned up, working machine.
cleaning your serger (avoid using compressed air as sometimes it will force lint and debris farther into the machine!)
Cleaning Your Serger
Serger Cleaning and Oiling
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Since your issue is with the stitch width function, you may want to focus more on that mechanism and work at getting it released. Sometimes applying heated air from a handheld hairdryer will loosen stuck mechanisms.
Jun 10, 2016 | Baby Lock Eclipse Serger
How can I fix a jammed, squeaky hand wheel?
This sounds like a bushing in your serger or the upper looper shaft heats up with use. This the swells the metal and seizes the machine. This is always hard to fix right because there are many points on the serger that need regular lube and can heat up. it is an eliminate 1 joint at a time and try agein
May 28, 2014 | Husqvarna Huskylock Computerized 910
Hand wheel turns half way and won't go any further,nothing appears to be hitting anything
Did you do a thorough oiing "inside" the machine--like take the bottom or back off, hand rotate the handwheel and apply a drop of "fresh, good quality serger oil" every place where metal rubs against metal?
Jun 11, 2017 | Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
Brother 1034d serger needles go up and not down
if a part has come loose or broken then the machine is not going to respond, it needs to be serviced
Mar 14, 2012 | Brother 1034D Mechanical Sewing Machine
I will like to know the difference beetwen Husqvarna Viking Huskylock 936 Serger sewing Machine and the 1001L. THank you. Huguette
Both machines are very close as to what stitches/functions they do. However the 1001 is older and way past the 5 year warranty period which makes getting parts more difficult. If I had to choose between the two, the 936 wins hand down!
Aug 31, 2010 | Husqvarna Freesia 425
My hand wheel on my serger is super tight and is barely turning, and basically the machine is not working?
your machine needs servicing. make sure you oil all spots indicated in your user manual and turn handwhel by hand for a minute or so to work oil in.
if this doesn't make machine easy to turn see a tech for full service.
scott
Jul 26, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Hand wheel loose
In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
May 09, 2009 | White Sewing 1418 Mechanical Sewing...
Hand wheel won't turn and machine won't work
  • Sewing machine has been run at a low speed for an extended period of time.
  • To prevent overheating, motor power is automatically turned off.
Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate, If this by chance doesn't work, Here is a diagram of a typical sewing machine. This fuse should be in the back next to the power box or motor564d4f7.gif
Jan 18, 2009 | Sewing Machines
Sewing Machines Logo
221 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
