Question about Toro Electric Trimmer
Wrapping string on Toro 1100 51325 electric heavy duty trimmer
Do I wrap each string in the opposite direction or both in the same direction?
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: It has come apart and I would like to refill the
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jun 25, 2009
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
  • 623 Answers
SOURCE: Toro& Electric String Trimmer: how do you take the bottom part off?...
Look for a couple small windows on the sides of the center knob that sticks out, push in on these, they are tabs that hold the center knob on, after that the string bobbin should slip right out.
Posted on May 19, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Jim
Jun 23, 2009 | Toro Garden
How do you get the head off of the 12/15" electric toro
After the bolts have been removed from the head, tap all the way around the head with a rubber mallet,
(http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=4760615&PMT4NO=65151144), where it meets the bottom of the motor. It should come off with a little coaxing.
Jim
Jun 09, 2009 | Toro& Electric String Trimmer
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Toro Electric Trimmer Logo
2,631 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
