Question about Riccar 8955 Upright Vacuum
Riccar 600FA hook drive gear
I recently replaced what the parts list describes as the Hook Drive Gear on my Riccar 600FA sewing machine, but I'm not able to figure out how to get it "re-aligned" so that the needle doesn't hit the shuttle race cover, shuttle race holder and/or the shuttle hook (whichever it may be hitting; appears to me to be the shuttle hook). The hook drive gear that I replaced was split completely with approximately a 1/16" gap and it seems that - like a motor driven machine - the "timing" is off but I cannot figure out where the adjustments need to be made in order to "re-align" it. Can you help?
4 Suggested Answers
  • 2418 Answers
SOURCE: hi i recently brought a
Here is a link to a site with threading diagrams for some Riccar models. www.sewusa.com Hope they have your model, if not look at the ones they have should be very similar. Hope this will fixya up...
Posted on Apr 25, 2011
  • 63 Answers
SOURCE: what size bobbin is used
class 15 A size
Posted on May 18, 2011
rockmeister
  • 2047 Answers
SOURCE: Problem with Riccar 8850 Vacuum There
Hello there, when sparks come flying out of your vacuum cleaner it usually is as a result of messed up connections and power fluctuations.The probability of the motor needing replacement is very high as unless i examine it i cannot say for certain but one thing i can say for certain is that the entire wiring of the unit has to be inspected thoroughly because this is where the main problem would have emanated from. The unit would definitely need other components other than the motor changed this is because if the other components which have been affected dont get replaced then even a new motor will face the same problem after a relatively short period. best refer the unit to an expert to determine the extent to which the other components are affected and what other parts are damaged. Also to determine if the entire motor needs replacement or some part of the motor can still be salvaged.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Sep 08, 2011
How do I replace Riccar 8625 upper cord hook?
There are various small parts that make up the hook. First insert the L bolt through hole in handle. Put cord holder on L bolt, put lock washer and nut on and tighten nut. Then put cord hook on L bolt followed by spring, large washer, lock nut and another nut. Snug nut up and test to be sure it will swivel.
Feb 19, 2015 | Riccar Vacuums
How to replace power cord hook
The lower cord hook is held in by a screw removed with a phillips screwdriver. The upper cord hook has a nut on an "L" shaped bolt. The "L" goes through the hole in the handle. Reassemble the cord hook parts in the same way they were before.
Feb 12, 2014 | Riccar 8955 Upright Vacuum
Parts schematic for riccar 8920 vacuum
I am looking for a new motor for my 8920 Ricaar Vacuum. All else works fine.
Jul 13, 2012 | Riccar Vacuums
I have just gotten 2 of the QUIKFIX by SINGER, both of them have the same problem. It wont bring up the bobbin thread, it doesnt even move( the bobbin) I went ahead and put my thread threw where it goes...
Hi. Not familiar with the Quickfix, but the name seems to imply that this is one of Singers lower cost machines. The bobbin shouldn't move, it should stay pretty much stationary. The part surrounding the bobbin, the hook, should move when machine rotates. More than likely these are light duty machines and the plastic gears that drive the hook are broken.
Sep 01, 2011 | Vacuums
Hi i recently brought a beautful riccar sewing machine in fab working order older style 1960s with no manual having trouble threading and can not find model numnber anywhere. any advive?
Apr 25, 2011 | Riccar Vacuums
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
I need a new belt drive gear.
Here's the Bosch website where you can order from the parts list . http://www.boschappliances.com/site_tools/orderparts.aspx?menu_id=34&menulevel=0304 Then click on Order Accessories and Additional Parts spacer.gif spacer.gif Looking for accessories for your Bosch range or cooktop? Or perhaps you're looking to purchase additional parts? Order here. blue_arrow_rt.gif
It will take you to another window. Type in the Model # BUC11700UC. It'll display the picture and part number. Click on the part # to order.
Nov 07, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Riccar 8955 Upright Vacuum Logo
106 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
