Question about Bella Kitchen Appliances - Others
Need stir rod
I need the stir rod and the black screw on piece to secure the rod in place. Where do I find this?
  • 13433 Answers
SOURCE: I need the stir rod
here
http://www.abtecparts.com/westbend_popcorn_82306.htm
Posted on Jun 23, 2008
SOURCE: Need missing gear that drives strirring rod for popcorn machine
Dear mpolly: I too am looking for the same gear I believe, if its the one that at the top of the long rod. Ours fell off as well and probably found by someone in there bag of pop corn. I will let you know if I find it.
Posted on Jul 18, 2008
  • 13433 Answers
SOURCE: stirring rod stopped
Hey,
The stirring rod is operated by a motor on the bottom of the popcorn maker, if the rod is not moving, it means the motor is not moviing either. Most likely faulty motor, and it should be replaceable by opening the bottom of the maker. If the motor rotates but the rod doesn't move, something is cut in between the motor and the rod.
Thanks,
Ekse
Posted on Aug 30, 2008
JosephBower3
  • 17 Answers
SOURCE: Stir rod and knob set
Hi I found a website for you
http://www.manufacturedfun.com/popcorn-machine-replacement-parts_p_-1,10,13,101.cfm
I hope this helps you. Have a great day.
Posted on Mar 19, 2009
SOURCE: Where can I buy a replacement plastic nut that
Where can I buy a replacement plastic nut that holds the stirring rod in place
Posted on Apr 09, 2010
My popcorn maker won't spin the kernels. I think it's the stir rod?
There are many possible problems that will cause your agitator to not spin, But you said the gear in the cabinet comes off easily, it should not.
There is a flat part of the motor shaft that extends thru the top of the cabinet that the gear should be tightened onto with an allen wrench via a set screw. This is the first place to check. When the motor is on, you should not be able to stop that cabinet gear from turning. (not easily anyway).
Oct 25, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Light red shows software
Back door wont close...just had this problem....
Look at the back of the printer and you will see a rod with two black pieces on it...it looks like the fins on the door will mesh with these pieces and close....but these are the problem.
Gently pull on the rod and flip the black pieces down so the square tab on them is up and back. This meant pushing the black piece FRONT down on my printer.
This spun the piece to the correct position. Repeat on the second black plastic piece on the rod and the door will close!
How they got turned on the first place is a mystery to me! But this fixed my door closing problem!
Dec 11, 2013 | Samsung CLP 300 Laser Printer
The stirring rod fell off. How do I fix this?
The center hub is screwed on. With the popper cold, try unscrewing the center piece. The stir wire sits in a channel under the center piece.
Sep 02, 2013 | West Bend 82306 Stir Crazy® Popcorn...
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
I have obtained a new motor for the rear passenger side wheel but am having trouble getting to the screws behind the rear wheel. How do I remove the wheel so that I can install the rear motor? ...
I had this same problem, but eventually figured it out.
The wheel comes off by removing the little black piece in the center of the yellow hubcap. There are a couple of snap tabs in this black piece, but it comes out well enough. You'll see the end of a metal rod going through the center of the wheels. Remove the star-looking washer and pull the wheel off. The other wheel will now come out as well, taking the rod with it.
Behind the wheel, you'll see 2 screws that hold the motor assembly in place. You'll also need to remove the seat and black cover to access the motor assembly.
Good luck.
Sep 07, 2010 | Peg Perego John Deere Turf Tractor
Where can I buy a replacement plastic nut that holds the stirring rod in place?
Mar 28, 2010 | West Bend 82306 Stir Crazy® Popcorn...
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Stirring rod stopped
Hey,
Thanks,
Ekse
Aug 07, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Kitchen Appliances - Others Logo
27 people viewed this question
Top Bella Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
richie46
ray gallant
Are you a Bella Kitchen Appliances - Other Expert? Answer questions, earn points and help others
