Question about LG Refrigerators
LG Fridge / Freezer GR409GQ 400LT FROST FREE UNIT NOT COOLING ENOUGH. PLEASE HELP.
Veggies in freezer section softening and water in bottles in fridge not cold.
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
SOURCE: Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Posted on Aug 04, 2009
  • 670 Answers
SOURCE: Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Posted on Jul 14, 2010
My LG Refrigarator with a top freezer and water dispenser is frosting on the freezer and the refrigerator is warm
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 12, 2011 | LG Refrigerators
LG electrocool fridge - serial no. 407KRXD00074; the frost free freezer has a huge ice build up, please assist. im also trying to find the manual book for the fridge.
Please check the link :
http://www.lg.com/us/support/product/support-product.jsp
Jul 19, 2011 | Refrigerators
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
My refrigerator is freezing inside the cooling section also there is water dripping inside the cooling section
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp and Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 10, 2009 | Refrigerators
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Freezer is working but the firdge part is not cooling.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
217 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
