Question about Intermatic T104 24h 208-277v Mechanical Time Switch
How do I wire my .CircuPool RJ20 Salt Systemto Mechanical Time Switch
How do I wire my .Circu Pool RJ20 Salt System to my Mechanical Time Switch
3 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: Need wiring diagram for Intermatic 240V Mechanical Time Switch
For anyone else who may be reading this post, these instructions are for the T104 ONLY.
Connect your incoming line) 240 volt wires to terminals #1 and 3. Connect the outgoing 240 volt (load) wires to terminals # 2 and 4. Don't forget to connect both equipment ground wires (bare or green) to the "GR" terminal.
Do NOT connect anything to the "A" terminal.
Posted on May 09, 2009
  • 56 Answers
SOURCE: i installed a intermatic t104m
Can you tell me if you have a meter to see if power is going through the timer?
Posted on Sep 29, 2010
We just installed a RJ 45 Circu pool Salt water system. When we turned it on the no flow light continues to blink and the generate light goes on and off. Any ideas?
Turn up the speed on your pump?
Ensure the filter is clean and no lines are clogged.
Otherwise call the manufacturer
Mar 26, 2017 | Pool & Spa
How can I reset my circu-pool salt generator? it is giving me a high salt light and a check cell light
I have a Circu-pool SJ45, no issues . Have you cleaned the cell. How old is unit. Have you checked pool salt level. Have not seen reset button, will look .
May 15, 2016 | CircuPool Swimming Pool Salt Water...
I have pool salt in my pool. Will the saltwater damage my sandfilter system?
No, the sand filter is a mechanical filter, and the salt should all be in solution.
May 03, 2016 | Pool & Spa
Is a saltwater swimming pool bad for you?
only if you live in it full time without showering in fresh water after .then you will get crusty.
Feb 13, 2016 | CircuPool Salt Water Pool System
Can I add salt and run new saltwater system?? Will it clea it??
if your asking will a new salt system clean my pool from a preseason condition , well no not really , salt systems are for maintaining a healthy pool water thru the season , see they use the salt ions to make chlorine , so I guess technically yes but it would take ten times longer to do it and by then the salt would be all used up (converted) , its much easier to use common pool chemicals to "start up" the pool then after a healthy chemistry is achieved then switch over to salt system , and even after u switch always keep an eye on your water chemistry(testing ) and your never will be surprised by an upset !!
Jun 23, 2015 | Pool & Spa
I'm getting salt lo msg.brand new unit, brand new water, 810 pounds of salt for ten days
Have you tested for salt content in the pool. Most salt generators require between 3000 and 5000 ppm of salt for it to operate correctly. How many gallon pool? 810 pounds of salt should make it around 30,000 gallons?
Jun 30, 2014 | CircuPool Salt Water Pool System
Wiring two 240 v loads to a switch
threw a intermatic t104 timer, hook the salt gen. to the same side as the motor .. you should have a timer already on the house for the pol pump ? use it the same way .. Jay the pool pump motor repair guy longwood Fl
Apr 06, 2012 | Hayward Pool & Spa
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
154 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
