Question about WYSE Winterm V90 Network Terminal
Problem booting the device
I am experiencing problems trying to boot my v90. It comes up with an error message saying: "The application has failed to start because MSVCP60.dll wa not found. Reinstalling this application may solve this problem." I have tried to push out an image to the machine from the server, but it does not accept it. Please help.
  • 82 Answers
Dear upgrade the system
Posted on Sep 20, 2007
Hi there, I hope someone can assist me with this
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
Aug 15, 2013 | RIM BlackBerry 7100G Smartphone
I have a dell E510, trying to do a fresh install of windows 7, but it wont boot from cd, or usb flash drive. boot order was changed to boot from cd first then usb second. after that failed hit f12 and...
Hello
If this is a win 7 upgrade you need to have xp installed first,then you can install win 7.
If not,then in the boot order change to cd dvd then hdd,if you have two hdd make sure your primary is first.
Last,if you have a xp disc boot from that and do a delete partion and format the hdd.Then try win 7
Apr 04, 2011 | Dell Dimension E510 PC Desktop
Error message that says boot disc error. there is
This is either a corrupt file system or a bad hard drive. You'll need to boot from a Rescue CD like BartPE or a Windows CD and run chkdsk on the drive to see if the file system has just become corrupt. If that fails, you may need to run "fixboot" and "fixmbr" from the recovery console. If those fail, or if chkdsk comes back and says it can't repair the damage, then you probably need a new hard drive.
Mar 19, 2010 | Acer Aspire™ T180 PC Desktop
Well got same problem as above when try to boot an error message comes up and says no bootable devices insert boot disk and press enter but it says my hard drive is not installed tried the start up f8 but...
This error means that the hard drive is either not connected properly or has failed. To fix it check and make sure the hard drive is connected properly and tight. If it is unfortunately that means the hard drive needs to be replaced.
Feb 26, 2010 | Acer Aspire 5315 Notebook
My computer starts to boot then once it is completed the a message comes up saying there is an error and then a blue screen comes up and reboots itself. THis continues and does not stop
When starting up, press the F8 key to catch the Boot Menu. Select the option to disable automatic restart on system failure. Boot and when it fails the Blue Screen will remain for you. Look near the top and see what file has been identified as the failure i.e. NV4_disp.dll. (Google the file name to see what program or hardware the failed file is associated with) Press and Hold the power button to shut down. Turn the computer back on and press the F8 key again to catch the Boot menu, and select Safe mode. If allowed into Safe Mode, try to go into Device Manager and either disable the failing device, or remove the associated program. If this doesn't work you can try to do a system restore to a date before this error started to appear. If you post back the file causing the blue screen, I can instruct you further.
Jan 10, 2010 | Fujitsu Computers & Internet
Error message says PXE-E61:media test failure check cable. PXE-M0F:exiting broad com PXErom. Reboot and select proper boot device or insert boot media in selected boot device and press any key.
PXE errors occur when the system attempts to boot to the network adapter and it fails to find a bootable network connection. In most systems, this is due to the hard drive not being detected in the system. So, reseat the HDD and ensure it is seen in the BIOS. If it is not seen in the bios then it has most likely failed and needs replacement.
Nov 03, 2009 | Computers & Internet
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
Error message on laptop boot up
You need to reinstall the modem driver ..
Dec 12, 2008 | Computers & Internet
WYSE Winterm V90 Network Terminal Logo
251 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
