What is Lint trap for your Toshiba AW 8500S washer
mark_37388
  • 100 Answers
SOURCE: just looking for the lint trap on my washer
It does not have one
Posted on Mar 30, 2009
jsrock516
  • 5911 Answers
SOURCE: need to know how to clean lint trap and where is
The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
Posted on Jun 23, 2009
  • 5 Answers
SOURCE: lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Posted on Oct 10, 2009
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
  • 14 Answers
SOURCE: hnwl 3136 lint in wash, how to clean
For general advice on cleaning a washer lint filter, try eHow: cleaning a washer lint filter.
Posted on Aug 09, 2010
Toshiba AW-SD150S error E71 what does it mean?
my washer Toshiba AW-SD150S washer can not funtion .it will come out error code E71.some body can tell me what is the problem
Jan 26, 2013 | Cell Phones
Is there a lint trap for this model? If so where?
There is no lint trap on these washers. The manufacturers are depending on the dryer to remove 80% of the lint. The only solution they give is when sorting the clothes separate the lint givers from the lint takers. Hope this helps
Sep 02, 2011 | Kenmore 22422 Top Load Washer
Need to locate lint trap on washer....affinity frigidare front load washer
There is no lint trap on this washer. There is a filter in the hose that goes from the tub to the pump that occasionally will get plugged with lint, but it is not designed to be regularly cleaned. During normal usage, the lint is designed to be pumped out with the water.
Kelly
May 25, 2011 | Washing Machines
I have TOSHIBA AW 8500 S washing machine... there is one part which located inside washing tub (part with net) where all dust nd all accumulated during washing, is comppletetly destroyed.... i want want...
Toshiba does not seem to support washers in USA. You should go to Toshiba worldwide support at http://www.toshiba.co.jp/worldwide/index.html. Select your country and follow the steps to get a phone number. Talk to a CSR and they should be able to give you a part number and/or dealer near you.
It sounds like you need the Lint trap for your Toshiba AW 8500S washer. Good luck!
Nov 29, 2010 | Washing Machines
Can't find the lint trap
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
Jun 28, 2010 | Estate TAWX700JQ Top Load Washer
Iget alot of lint in my laundry cant find lint
May 15, 2010 | Amana NAV2335A Top Load Washer
Where does the fluff go when you use the dryer on
The lint should go in the lint trap. If it doesn't go in the lint trap it goes out the exhaust pipe if the lint trap is not installed.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Kenmore 100 washer leaves tons of lint
Remove the hoses from the pump. The lint trap will be there.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 16, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
