Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Bent connecting rod
Stihl MS 210 chainsaw. After about an 1 1/2 years the saw was probably used a total of 6 hours. When trying to start it backfired back through the carb and was hard to crank. Upon inspection I found the connecting rod was bent. A new one came with the crank and piston and was half the price of the saw. After installing the new one it started first crank and ran fine for about 8 months and is now backfiring through the carb and getting stiff to crank. I'm sure it is the connecting rod again. What would cause the rod to bend. It is an easy start system and you can't crank or pull to hard on it.
  • 149 Answers
Ive had blower with bent cranks due to blower scroll comming off and the engine over reved
Posted on Jan 31, 2009
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
What is the difference in a Stihl 025 chainsaw and a ms025 chainsaw
nothing it's the same . stihl never used the ms back when the 025's were produced. later they changed to calling all their saws ms but the 025 is equivalent to a ms 250 I believe
Sep 28, 2014 | Stihl Garden
How do I change a chain on a Stihl ms 210?
Take off the side cover at the base and loosen the tension screw. Blade should slip off. Make sure when you replace it, you do not tighten it too far.
Sep 20, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Stihl ms 210 manual
Here is website for manual:
Sep 08, 2014 | Garden
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual:
Spark plug (resistor type): Bosch WSR 6 F
Electrode gap: 0.02 in. (0.5 mm)
Apr 28, 2014 | Standard Oregon Chainsaw Chain For Stihl...
I have a Stihl 039 chainsaw that kicks back when starting.
check for a sheared or bent flywheel key...
Dec 03, 2013 | Stihl Garden
Where do I find a operating manual for my STIHL 210 Chain Saw ?
Don't believe everything you read.
Your OM can be found here:
Stihl Product Instruction Manuals
This was returned from my attempt:
IPLs (parts lists) are proprietary and not available to anyone not a Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
Mar 21, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
692 people viewed this question
Top Makita Garden Experts
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
