Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Change vga cable for compaq fp 7317 - HP Compaq FP 7317 17" Flat Panel LCD Monitor
5 Suggested Answers
  • 14 Answers
SOURCE: Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Posted on Jan 05, 2006
SOURCE: Compaq FP 7317
To close this thread, I just wanted to let you know that I decided to replace my monitor. I'm about 99.9% certain that the inverter is bad. After searching numerous sources including HP, I concluded that the required parts are not sold to the public. The inverter is a common failure in LCD monitors, so buying a used monitor for parts wasn't a good idea. Since I had to buy a new monitor, I decided to upgrade to a 20". I'm disappointed that my monitor only lasted 2 1/2 years, but maybe that's the norm these days. For what it's worth, the inverter board on my IBM Thinkpad went out about 3 years ago after nearly 5 years of service. IBM sold the circuit board for about $30. I replaced it myself and saved my $4,000 (at that time) laptop. I will never again buy a Compaq computer or monitor - too many quality issues with my desktop and laptop (R3000), and HP doesn't sell internal parts to consumers. If something breaks, good luck fixing it. What could be an inexpensive repair, turns into an expensive replacement. Thanks again for your kind assistance. Best regards, dzimmer
Posted on Mar 31, 2007
JulesPCaut
  • 702 Answers
SOURCE: Low volume on HP Compaq FP 7317.
You can try using an audio enhancer. That can boost your audio volume a bit.
Check out: http://www.pcauthorities.com/multimedia/how-to-boost-laptop-audio
Works for PC's as well as laptops.
Jules
Posted on Mar 29, 2009
  • 224 Answers
SOURCE: Hi,.. I was given a compaq FP 7317 with the tower,
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Posted on Jun 28, 2011
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
Can i order the cord that hook up to the computer
Yes, this cord is called a VGA. You can do a google search for it, or go to your local computer store, they should have it.
Jan 19, 2010 | Compaq FP 7317 17" LCD Monitor
I have the compaq FP 7317 monitor and the speakers on it dont seem to work how can i fix it? i tryed plugging in other speakers but those work either
Make sure that your soundcard is properly installed as are it's drivers. Check to see that sound is not muted. This can be done via the speaker icon in the system tray or from sound in control panel.
Aug 12, 2009 | Compaq FP 7317 17" LCD Monitor
Jules
Jan 12, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Speakers
Sounds like you need to re-install your sound drivers.
Apr 09, 2008 | Compaq FP 7317 17" LCD Monitor
Check Signal Cable
there maybe something called source on th screen somewere push that button
Nov 19, 2007 | HP Compaq FP 7317 17" Flat Panel LCD...
Compaq FP 7317 LCD monitor flickering
try with change the resolution .it will littl ebit help out . othewise show it service personnel. bye
Oct 01, 2007 | Compaq FP 7317 17" LCD Monitor
Fp 7317
My monitors green light stays on, but the screen will come on for a second then goes off
comaq fp737
any ideals
May 15, 2007 | Compaq FP 7317 17" LCD Monitor
Compaq FP 7317 Speaker / Sound Problem
Sounds like the sound card in your computer..
Dec 27, 2006 | Compaq FP 7317 17" LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
