Question about Titan 440 Impact Airless Paint Sprayer 440i 805-015
Titan 640i wont prime - Titan 440 Impact Airless Paint Sprayer 440i 805-015
    New Friend:
  • 50 Answers
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Posted on Jan 17, 2013
2 Suggested Answers
  • 98 Answers
SOURCE: titan 440e wont prime
i can help if i know the manufacture or had a picture.
quite possibly the lower / inlet ball valve is sticking or has someting stoping it from seating properly. so your fluid is going in and out the inlet.
Posted on Feb 21, 2010
My titan 440i primes but wont stop in priming when in spray position
I am not very familiar with airless sprayers but try this link to a youtube video...
https://www.youtube.com/watch?v=5DGUHwBmdaM
May 12, 2017 | Air Tools & Compressors
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
Titan xl 250 wont prime,ball is not stuck
Your prime system needs to be cleaned . Read on how to correctly clean mechine after each use
Apr 09, 2014 | Titan Xl 255, xt 250 Airless Paint Sprayer
Titan 440 wont prime
You don't clean it right what do you expect
Apr 09, 2014 | Titan Impact 440 Skid Airless Paint...
I have a titan 640i paint sprayer and i am repacking the fluid section for the first time myself and can't seem to figure out how the piston rod comes apart? In the manual it shows it coming apart so
You likely have titan 440 i .I have a 1991 660 its the same packing kit as the 440 except one has flat valves and the other has balls flat valve is better if you use it a lot like I do but the instuuctions on how to repack the unit are simple .The most expensive part is the pistion 400.00 dollars . Its all nylon and neaprem O rings 60.00 bucks for the kit. The olny way to take it apart is from the bottom and the pistion slides out after the block that houses the packings is removed from the bottom of the unit . Read the repacking insturections again.By comparisition this is the easest pump I have ever had to rebuild and work the best a good little mechine
Feb 14, 2014 | Air Tools & Compressors
Wont prime
tap lightly on the fluid section with a hammer or take off suction hose and clean the ball bearing
Oct 10, 2013 | Titan Air Tools & Compressors
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Titan 440e wont prime,ran perfectly last time
Jan 31, 2010 | Titan Air Tools & Compressors
Sony erricsson 640i
yeah sell him
Apr 05, 2008 | Cell Phones
Titan 440 Impact Airless Paint Sprayer 440i 805-015 Logo
339 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
