Question about Bose LIFESTYLE 28 Series III System
Volume control My bose lifestyle volume will not go up or down? The numbers go up and down on the media centre display, however the volume will not change at all? It seems to be stuck around mid volume??
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Posted on May 04, 2009
Bose lifestyle plays for 5min shuts down
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Jan 13, 2013 | Bose Lifestyle 8 series II System
Tip
Bose LifeStyle 38 Video Mode
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Reset Bose LifeStyle 38 VChip Password
on May 02, 2010 | Televison & Video
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
I hope that helps.
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
Volume is blocked ("hotel only"). How can I
I found this in another Fixya entry... "-Press Enter and On/Off on the media center , on standby mode -now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON - on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off." My next suggestion would have been to call Bose and ask them why things like this aren't documented anywhere. 1-800-999-2673 Sales support: Mon. - Sun., 7 AM - 2 AM ET Technical support: Mon. - Fri., 8:30 AM - 9 PM ET Sat., 9 AM - 6 PM
REALLY - call them and complain that this is NOT documented online.
Mar 05, 2011 | Bose Lifestyle V20 System - black Theater...
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
Tip
I hope that helps.
on May 02, 2010 | Bose Lifestyle 38 System
Tip
I hope that helps.
on May 02, 2010 | Bose Lifestyle 48 System
Lifestyle 48 Acoustic module doesn't work
Call Bose tech support. They fix or replace these under warranty. I have a lifestyle 12, original model, after two repairs in. Ore than 10 years, I was allowed to upgrade to top of the line for the price difference.
Mar 16, 2017 | Bose Lifestyle 48 System
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
Bose LIFESTYLE 28 Series III System Logo
351 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
