Question about Olevia LT26HVX 26 in. LCD Television
Lcd tv picture problem
I have a Olevia LCD HDTV, 26" a little over 2 years old and out of warranty of course. When you first turn it on it's perfect, but after it's been on for 30 minutes or so it gets a horizontal thin black line a few inches down from the top. I'm sure this is nothing I can fix, but was really wondering if any one knew if it was fixable by a repair shop and whether it was going to be an expensive fix. Thanks.I cannot get the color to adjust properly on my Olevia LT26
  • 50 Answers
Hi
Please find the link to download manual and troubleshooting step, hope it will help
http://www.olevia.com/en-us/Support.aspx#1
onemore link for support is
http://www.retrevo.com/support/Olevia-LT26HVX-TVs-manual/id/563ci877/t/2/
Good Luck
Posted on Jan 18, 2009
    President:
  • 373 Answers
This is from the Olevia website related to troubleshooting
For troubleshooting click here
Also try this for their customer support
Customer support for olevia(enter the model number in the space allocated
The problem is not so common in terms of occuring but yes it could be expensive.Depending on the charges levied by Olevia,
    Brigadier General:
  • 8,619 Answers
Hi
The mainboard of the TV is not good and would cost you around $500-$650 .
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 18, 2009
    Also the connections from Mainboard to Lcd gets loosened overtime and due to this the charge doesnt flow in the lcd properly so you can also check for those connections.
    Thanks
    Rylee
  • 10,594 Answers
It would be an expensive fix because LCD Panel is defective.
LCD Panel has tapping bond for signal flow in Crystals and it seems one of that bonds is not working properly. It is not repair shop level repair and LCD Panel needs to be replaced which of course cost you around new TV price.
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
26" Sanyo HDTV LCD Model
board burnt out where can i purchase a new one
Apr 02, 2011 | Sanyo DP26649 26 in. TV
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
L have an olevia flat screen tv that turns off on its own whenever... what could it be?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Apr 04, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Nov 03, 2008 | Olevia LT42HVi 42 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
I have the same problem, too!
If your LCD is 8 months old, still under manufacturers warranty. I would call them back and ask them to provide you with a telephone number of their nearest service center to you and have it repair under warranty. The failure is with the video board or main board.
Good Luck.
Sep 12, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
Open Questions:
Olevia LT26HVX 26 in. LCD Television Logo
126 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
