Question about GE WBSR3140DW Top Load Washer
GE washer won't agitate or spin
I have a GE washer M# wwse5240g2ww. It stopped agitating and spinning. there is a light(code) on motor that says that belt was slipping. I replaced belt but it still reads belt problem. how could i remove or reset code The spec sheets looks like it tells you how to reset but that part is damaged and unreadable.
  • 1 more comment
  • Amy_Logan78 Feb 16, 2009
    It seems like I have the same problem as above. I am however just a consumer so I don'[t have access to the code on the motor. My washer is just not agitating or spinning properly. There is also a horrible noise and seems to become unbalanced easily.
  • Anonymous Mar 02, 2009
    I was having the same problem with the washer not agitating or spinning properly. The washer became unbalanced easily and was making a loud noise. My washer was under warranty, so GE sent out a repair man and the washer had to be replaced. The struts were bad, it was having electrical issues, and the constant unbalancing due to damaged struts also damaged the exterior of the machine.
  • Anonymous Mar 19, 2014
    have determined it is not a motor reset problem, there was a very heavy load in the machine when it failed, it will pump water in and out of the machine, the belt does not turn when it should be spinning
  • 61 Answers
Un plug the machine , wait 30 sec. plug back in , open and close the lid completly 5 times with in 30 sec. if the problem is just needing to be reset this will do it if not you need to replace the motor
Posted on Jan 21, 2009
  • bjray23
    bjray23 Sep 23, 2012
    Unplug the machine. Wait approximately 1 minute. Plug it back in. You now have 30 seconds to open and close the lid SIX times within TWELVE seconds. No need to open the lid all the way... open it just enough to deactivate the lid switch then close again.
SOURCE:
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
2,423 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
