Question about Refrigerators
My samsung sr503nts freezer is working the refrigerator is not
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Hi, I have a Samsung
Most samsung have a separate evaporator coil just for the fridge side. Check it out. If it's the other kind then The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 08, 2010
Freezer not working flashing -8
samsung unit are dual cool meaning as longer compressor don't fail refrigerator will work even if freezer fail and vice-verse. If freezer is not working and refrigerator must like you have defrost problem which is very common in Samsung unit, can be something as simple as a sensor or it can also be the heating element. also check the temp in the freezer it can also be the evaporator fan
Dec 20, 2014 | Samsung RF265AA Bottom Freezer French Door...
My refrigerator is not working on my samsung tyhe freezer does work perfectly just need help with the product
On some refrigerators there is a chute that lets cold air from the freezer section into the refrigerator side. If this fails to open than the refrigerator will not chill.
Also a refrigerator low on charge will act like yours.
Oct 22, 2014 | Samsung RF263AEBP - 26 cu. ft. French Door...
Why freezer part is not working on my samsung rb2055sl
The most common part to replace is the timer motor. It's usually located on the back bottom of fridge, It's a little thingy about 1 1/2 " in diameter. One screw will usually get it loose where you can take a look at it better to see if it's turning. It has a small window where you can see a little wheel turning.
Sep 05, 2014 | Samsung RF265AA Bottom Freezer French Door...
I Have a Samsung fridge model SR503NTS, It was working perfectly then today i go to get a drink and fine a thin layer of ice on the surface of the jug. I reliase the fridge is cooler than it should be when...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 03, 2011 | Refrigerators
Samsung refrigerator model rs2545sh/xaa. Freezer works good, but refer side does get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
My samsung fridge section stops cooling but freezer is working
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Samsung Refrigerators
My samsung fridge 18 months old. the freezer is working so so, however the refridgerator is not working at all any ideas.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 27, 2010 | Samsung RS2578BB Side by Side Refrigerator
Samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Apr 28, 2010 | Refrigerators
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
