Question about Electrolux Vacuums
Volta forte vacuum red light is on and no suction, please help?
  • 22 Answers
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Posted on Feb 10, 2009
  • 75 Answers
SOURCE: volta ultima 2000 watt vacumn - hardly any suction at all
change your bag.or your motor is going bad so have that looked at.
Posted on Jul 03, 2009
  • 341 Answers
SOURCE: Royal vacuum has no suction
If a vacuum has not suction then there has to be something plugged up in the port. You will probably have to remove the bottom. Either with a bag or bagless, find the suction port and usually it's plugged with all kinds of stuff. Sometimes if you have access to compressed air you could blow it out from where the bag hooks up or if bagless where it empties into the container. It's not that unusual for it to plug up. My parents have old old old carpet from I think the 70's, (The shag type that you can use a rake with) and there vacuum is always getting plugged up. Good luck.
Posted on Jul 25, 2009
fixdat22
  • 34 Answers
SOURCE: My S 7000 upright vacuum red carp light on
its probobly the belt is broken
Posted on Sep 12, 2009
  • 159 Answers
SOURCE: I have a volta ultima vacuum and the brush won't t...
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
Posted on May 19, 2010
My Volta vaccum is sucking strongly using tools but not when using floor vaccum
what blocks the suction hose when not in use . our dyson has a slide plate at end of hose
Feb 14, 2015 | Vacuums
Hoover s3765
There may still be a clog or restriction somewhere. If the hose. Has good suction the problem may be. In the wand and floor tool.
Mar 21, 2014 | Vacuums
When I turn on my dyson animal vacuum the red light flashes on and off and there is no suction
I think you have a blocked pipe somewhere. I use a large marble to drop through the pipes to see where the problem is.
Mar 11, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Volta vortex 2200w vacuum cleaner
See if the company will fix it under warranty. If not, you can take it apart and look for the obstruction. It sounds like something is inside obstruction the air-suction flow path. Normally the motor or controller would not cause the motor torque to drop.
Apr 02, 2017 | Vacuums
No suction
Hi there SmartAlec from NelsonVacuums.com.au here. The problem is going to be the filter. THis kind of vacuum basically replaces the bag with a simple filter and the vacuum cleaner simply pulls all the dirt on to the filter so as soon as you start vacuuming you lose suction. The more expensive bagless vacuums spin the dirt through a chamber to minimise the material getting to the filter but unfortunately that wont help you. I could be wrong but i fix vacuums for a living and see this all the time. ITs a bit of a silly design in my opinion. You can test my theory by removing the filter and really thoroughly cleaning the little cracks with a brush or better still an air compressor and the suction will improve...untill you vacuum dirt that is.
Hope this helps, if you want more info just drop me an email.
Happy vacuuming :)
Aug 30, 2009 | Vacuums
Volta ultima 2000 watt vacumn - hardly any suction at all
Jul 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore vacuum model 37105 no suction
Jan 26, 2009 | Kenmore Vacuums
Bissel Pro Heat Turbo attachment does not work.
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
110 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
