Question about Maytag Neptune MAH5500B Front Load Washer
Asko front loading washer won't fill with water
Machine comes on makes noise starts spinning but then stops
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
Daniel S
  • 4323 Answers
SOURCE: Problem with the Maytag Neptune MAH5500B Front
Hi
Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 17, 2011
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
My front loader won't spin - the machine makes a noise when it is supposed to spin but nothing happens
sounds like a bad pump open the sumpm on the lower left side (preapre water to gush out if still in the tub) check if there is any objects in the pump or sump if yes remove and try if not replace the pump
Sep 02, 2011 | Asko W6021 Front Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
