Question about Canon PowerShot A85 Digital Camera
Lightning bolt effect pictures
When I look at the back of my camera I have a partial picture showing, almost like a lightning bolt--with the sides in black and the "lightning bolt" having some picture in it. How do I fix this?
    Genius:
  • 2,985 Answers
Check the Manual to see if there is a 'Reset' feature Contact Canon Technical Support team There is no self fix- it is either a connector or circuit board failure If less than a year old- perhaps a replacement may be available Canon will know.
Posted on Jun 24, 2007
SOURCE:
I want to turn of the flash for an indoor picture how do I do this
Push UP on the lightning bolt located right above "OK" on the back of your camera until it shows an icon with a circle around and line through the lightning bolt.This should force the flash OFF.
Hope this helps.
Thomas
Sep 08, 2011 | Nikon COOLPIX L18 Digital Camera
We purchased the cannon and we started having issues taking pictures. the following issues have ocurred: 1) When we take a picture the flash flickers and the picture doesn't take. 2) When we take a...
I'm going to assume the pictures you have on the camera are not worth keeping. I'm going to assume you have the owners manual so the first thing I'd like your to do is check to make sure the SD card is unlocked here is a diagram.
Next I would like your to format the memory SD card page 40 of your manual here is the best diagram I can provide.
Once this has been completed turn the Main Dial page 16 to "P" program and the camera will begin making correct pictures.
If you are inside and a flash is needed use the button on the forward side of the camera the one with the lightning bolt an the internal flash will pop up and charge. Look through the viewfinder and partially (half depress) the shutter button look for your green dot in focus indicator and the green lightning bolt to come on (when the flash is in use) compose your picture and depress the shutter button the rest of the way. You have just made a picture. Study your manual and have fun with your new camera
Dec 26, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
How do you turn the flash off on a kodak easy share c813
Press the flash button (marked with a lightning bolt symbol, next to the on/off button) repeatedly to cycle through the different flash modes. The four available modes are Auto (lightning bolt and letter "A"), which flashes when needed; Fill (lightning bolt), which always flashes to fill in shadows, Redeye (eye), which flashes once to dilate the subject's pupils then flashes again to take the picture, and Off (lightning bolt in a circle with a slash through it), which never flashes.
Jun 17, 2010 | Kodak Easyshare C813 Digital Camera
Flash not working, blured pictures
Do you have the flash turned off? Does the screen show a lightning bolt with a line through it? If so, press the button with the lightning bolt and watch the screen for a lightning bolt and an "a".
Jan 28, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Jan 28, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
The flash will not work. I think something needs to be reset but not sure how to do that.
On the Navigaton direction button on the back of the camera the "Right direction" button has a little lightning bolt sign.
Repeatedly press this button while the camera is in picture taking mode to go through the flash settings sequence. (Watch the display while pressing this button)
Settings:
1 No Flash, Lightning bolt circled with slash across it.
2 Auto Flash, Lightning bolt with an "A" beside it.
3 Auto RedEye remover, includes an "eye" symbol.
4 Flash Always On, Lightning bolt alone.
5 Unknown, I don't know what the S mode is, I haven't used that one before (something to do with ISO virtual film speed setting).
Have fun.
Jan 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
My flash does not seem to be working, I tried just about everything but it wont work. it all started when I pressed reset im pretty sure, but im not postive. please help me.
Pressing reset would not disable your flash. On the screen, does a lightning bolt icon appear? Is there a letter A or the word auto next to it? Or does the lightning bolt have a diagonal line through it? In any case, press the button on the back of your camera with the picture of the lightning bolt until the lightning bolt with "A" or "auto" appears next to it on the screen.
Dec 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
How do i turn the flash back on my camera?
You don't say what model camera you have but usually, you just press the button with the picture of a lightning bolt until the lightning bolt appears on the screen.
Nov 09, 2009 | Cameras
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot A85 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
