Question about GE Energy Star WCVH6260F Front Load Washer
My GE front load washer WCVH6260 is leaking water from bottom
  • Anonymous Feb 02, 2009
    PLEASE HELP
We believe a shirt sleeve was not fully in our GE GCVH6260 front loading washer. With the twisting and turning the shirt pulled our rubber door seal into the washer, stretching the seal. The rubber door seal is formally called a; "front door boot gasket". (image of washer type linked below)
http://di1.shopping.com/images1/pi/e8/78/fb/28130826-177x150-0-0.jpg
We contacted our local GE store and picked up the replacement boot gasket (part# WH08X10036), which cost about $155 plus tax CDN.
Please Note; I did not remove the front face of the washer..
1. I cut away the old rubber ring as I did not have the "carny hands" needed to loosen the inner ring nut and bolt.
2. I then used a mini hack saw to cut the screw in half (careful not to cut anything else).
3. Once the old rings were removed, I filled the bath tub / laundry tub up with very hot water and submierged the new boot gasket into the water for five minutes.
4. Once heated, I quickly lined up the ring to the proper positioning and was able to put the ring on the washer with little effort.
5. As the ring cooled in place, I put the inner metal ring back into the appropriate groove. As I could not reach in an put a proper nut and bolt into place, I opted to use two thick zip ties to hold the ring in place, pulling it tighter with my pliers on the end and snipping the excess legging off after.
6. The outer ring was relatively easy to put on afterwards.
Special thanks to my pops, Warren McDonald for his great advise on heating the ring to put it in place!
Posted on Feb 14, 2009
How do I replace the door gasket on my front load GE washer
Posted on Jan 20, 2009
3 Suggested Answers
  • 2920 Answers
SOURCE: GE WCVH6260 Front Load leaking water from bottom of the door
you have a bad door seal
Posted on Jan 17, 2009
milten1
  • 1304 Answers
SOURCE: Washer, Front load #WCVH6260 F W W - trying to
use a theromstat screwdriver,
ver small flat head, push it betwen the detent
and the clamp it should release right away
Posted on Oct 03, 2009
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
When washing a load the machine is not spinning.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
Oct 03, 2009 | General Electric WSSH300G Front Load...
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260
Quite possible your pump is clogged, you have to dismantle.
Try these sites:
espares.co.uk
RepairClinic.com
AppliancePartsPros.com
Pl rate me.....................
May 31, 2008 | GE Energy Star WCVH6260F Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Mar 16, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
934 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
