Question about Dell Latitude D810 PC Notebook
Cardbus NIC boot failed on dell latitude d810 laptop
  • 998 Answers
SOURCE: Dell Latitude c540/640
Windows Vista is not supported on Dell Latitude C540/C640. There are no drivers for the hardware of this model. Many older computers have that problem. You can try Microsoft to see if they even exist: http://www.microsoft.com/uk/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
You might have to fall back to XP.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 27, 2008
Geekman
  • 32281 Answers
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Posted on Nov 23, 2008
Geekman
  • 32281 Answers
SOURCE: dell latitude d810 drivers
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Mar 23, 2009
  • 202 Answers
SOURCE: ethernet drivers for dell latitude d810
Here's a link to the Dell Latitude D810 drivers download page. I would suggest that you also check the BIOS and download that if yours is out of date.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D810&os=WW1&osl=en&catid=&impid=
Good luck and please let me know how this works out for you.
~ Spoem
Posted on Mar 26, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My Dell Latitude D830 will not boot up?
Your boot up needs to be repaired...follow the following repair and you should get booted back up. I do believe however that you are losing your hard drive, so watch it carefully and think about getting a backup for your files.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 12, 2009
Cardbus nic boot fail
Go to BIOS settings and check what is the order of BOOT devices there. Ensure that you have HDD as the first option if you want to boot from a hard drive. You can accordingly chose the 2nd and 3rd options to fit your requirement
Dec 29, 2013 | Dell Latitude D610 Laptop Computer -...
Cardbus nic not found
I would run a registry cleaner programme as that does not sound like a valid error.
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
Please give us more details. Not sure what you mean.
May 08, 2012 | Dell Lattitude D600 Notebook
Cardbus NIC is failed
If you are saying your NIC is bad then you will have to have it repaired.
You could use an alternative method of getting a nic instead of repairing. You could use a device that plugs into your usb port that gives you a nic connection. You could also use a device that plugs into the pcmcia slot that gives you a nic connection.
Try Tiger Direct for purchasing alternatives for under $20
Below is a link to a usb to nic
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=443248&CatId=589
Below is a link to Pcmcia to nic
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=308770&CatId=588
May 08, 2012 | Dell Latitude D600 Notebook
Dell 810 says it has no wireless adapters.
The wireless adapter on the D810 was an optional component and therefore it is possible you did not have installed. You can go to control panel - administrative tools - computer management and click on the device manager on the left hand side to determine the installed components in your system. If you find that the network adapter is not there, you can purchase a USB NIC for about $10.00 these days and install that. It will work the same, if not better than the one installed.
Sep 17, 2011 | Dell Latitude D810 PC Notebook
Very dark display screen almost black,dell latitude d810
Hi
Thank you for your query
Please try the following key combination
fn + Up Arrow
fn + Right arrow
If the above fail then it will be the inverter of the screen which will need to be replaced, please book the laptop into a reputable PC shop for replair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 22, 2010 | Dell Latitude C610 Notebook
Dell latitude d810 will not boot up; stuck after dell logo.
boot file is corrupt...
re-install OS
visit my site
http://www.sureshayyar.110mb.com/
FormatDisk page has all resloution of problem
Jan 16, 2010 | Computers & Internet
Ethernet drivers for dell latitude d810
~ Spoem
Mar 26, 2009 | Dell Latitude D810 PC Notebook
Dell Latitude D810 PC Notebook Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
