Question about Pitco Frialator SG14 Deep Fryer
Waldorf fryer pilot light won't stay on from start
SOURCE: pitco fryer pilot out
the problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
wiznet2000
  • 86 Answers
SOURCE: fryer wont fire up
Check the continuity, flip the switch on and off using an ohmmeter, if the switch is ok, check the thermal fuse inside.(you have to open the unit) replace whatever is defective
Posted on Jun 28, 2009
  • 86 Answers
SOURCE: high limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Posted on Jul 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Pitco 35C+ fryer. Pilot lights fine; main burner
Its a simple design. If the thermophile does the work of powering the fryer control. Do you have a good pilot flame? If the pilot flame ain't good enough then the millivolts won't be enough to operate the solenoid on the gas valve. Most folks replace both the pilot and thermophile on these fryers since the grease makes such a mess of everything. If the pilot generator is fine then the gas valve is next.
Posted on Jun 01, 2011
kebah
  • 683 Answers
SOURCE: 13 year old pitco frialator fryer pilot wont stay
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Posted on Aug 28, 2011
I have got lincat fryer j10 the pilot won't stay
Hi there.
Make sure that the thermopile is receiving enough heat from the pilot and if it does, check if the hi limit is good, check and tighten also all of the wiring connections, before replacing the gas valve.
Regards.
Jun 11, 2013 | Kitchen Appliances - Others
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
Jul 16, 2011 | Imperial IFS40 Deep Fryer
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Feb 10, 2008 | Pitco Frialator SG14 Deep Fryer
Pilot wont light.
Firstly make sure the gas knob is exactly in the pilot mode some are finiky and won't light unless in exactly the right postion. Make sure once lit when pushing down on the pilot knob that you hold it down long enough for the thermocouple to sense the pilot. Barring both of those the most likley culprit is the thermocouple itself is faulty and can easily be removed usally with a couple of screws and a small adjustable wrench.
Dec 29, 2007 | Imperial IFS40 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
