Question about Dryers
No heat in my Kenmore clothes dryer
My clothes spin, but no heat...
I understand I may need to replace the "element" - but don't know where to find it...
model #11070982990
    President:
  • 373 Answers
You can find any part for this model in the following link.Good luck.Please do rate my solution if accepted.
click here for parts of kenmore dryer model #11070982990
Posted on Jan 18, 2009
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
My kenmore HE2 is not drying clothes. It turn s on and spins clothes but does not have heat. It is an all electic front loading dryer
If the dryer is not heating at all the three things that you want to check are going to be the heating element, the high limit thermostat and the thermostat. The high limit and the normal thermostat are going to be located on the heating element itself. All of these can checked with a volt meter set to check continuity. To access these depends on if the dryer has a two piece front or a solid front.If solid, Then you will just remove the back of the dryer and the heating element and thermostats will be located on the right hand side as your facing it, If a two piece, you'll need to remove the kick plate and the parts will be located on the right side once again. Just remember to unplug the machine , 220v hurts, trust me.
Aug 31, 2012 | Kenmore Dryers
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
Sep 12, 2011 | Kenmore Dryers
My kenmore elite dryer will not heat. There is no obstruction in the vent (I have run it without the vent hooked up).
You probably need to replace the heating element. It is located behind the drum that the clothes spin in.
Feb 10, 2010 | Kenmore Dryers
Kenmore 86870800 Will not heat...
The reason to this problem is due to the faulty heating element.
Once the dryer runs with no heat then there is a problem in the
heating element which cannot be repaired,so you need to
replace it.
Sep 01, 2009 | Kenmore 63942 Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 15, 2008 | Kenmore 74602 Gas Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
