Looking for lg dvd recorder dr275 laser lens unit
  • 5 Answers
SOURCE: How do i hack into the LG DR275 Recorder to make it region free?
Press setup, go down to the lock symbol. do not enter it, just have it highlighted, then press "0" seven times. this will make it region free. also applies to most LG DVD players and DVD recorders.
Posted on Jan 11, 2008
SOURCE: LG DR275 UK version region unlock
1)Power on with no disc.
2) press et up.
3) Go to lock symbol (do not select).
4) Press zero - 0 seven times.
5) Shows open for all zones on screen.
Worked for me in South Africa hope it works in th UK
Posted on May 19, 2008
SOURCE: recording on lg dr275
There is CGMS protection on your analog signal. When your recorder see's this, it craps out. You need to purchase a filter to remove this restriction. If you google CGMS filter or enter CGMS on Ebay, you will find suppliers.
Posted on Jan 04, 2009
CLEONTI
  • 33 Answers
SOURCE: i need the manual of dvd recorder model dr275
You can find the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/DR275-_D
Click on the download link on the right side, then enter the 4 numbers so you can download the manual.
If you appreciate the time I took to help with this, please take the time to rate my response.
Hope this helps,
Chris
Posted on Mar 24, 2009
paul1964100
SOURCE: Problem with LG DR275 Recorder
lens needs cleaning or replacing
Posted on May 10, 2009
I have an DR275 LG DVD recorder. For some reason it stopped playing DVD discs. But it will play anything else you put in it I have cleaned the heads switch it of by the power as well. What could...
The laser mechanism has a number of optical components, not just the lens. There also additional fixed lenses and mirrors inside the laser unit which are very difficult to access. If sufficient dirt builds up on these components then the dvd laser may not work properly. Unfortunately it is very difficult (or even impossible) to clean these parts.
Another possible fault is that the CD laser is usually separate to the DVD laser and the DVD laser is no longer working properly, while the CD laser is still OK. In this case, the unit is definately not repairable without replacing the whole laser unit (not a readily available item and not likely to be cheap).
If the unit is out of warranty, your cheapest option is to buy a new DVD recorder.
Jun 16, 2011 | LG DR275 Recorder
Only records for a few minutes - even on a new disc. Only started doing that recently.
Your problem seems to be the laser lens.
You can try to apply some grease to the laser guides first to make sure it's not a problem of the laser getting stuck along the guides.
If this doesn't solve the problem, you'll have to change the optical unit though i'm affraid this will be an expensive fix.
Apr 07, 2011 | LG DR275 Recorder
LG DR389 "Unknown Disc. Please check disc again"
my lg dvd model dr389 displays PRO1 please solve my problem
Dec 18, 2009 | LG DR275 Recorder
Dvds not playin
It may be a problem with the laser or the lens. If the DVDs work on another player, try first to have the lens cleaned. You may use a lens cleaner with cleaning solution for this one. If that does not work, you have to inspect the disc drive closely and check for physical damages on the circuit like burnt parts or leaking capacitors. Inspect the lens as well.
Oct 30, 2009 | LG DR275 Recorder
My LG DR275,was all ok,now every time i put any disc in it says "Unknown Disc Please check disc again" . Please help!
Hi, have u tried cleaning the lens ? if so theres is problem with the cd compatment ie the lens could be damaged or the mechanism. may be the position of the lens can't let it read cd's
Aug 31, 2009 | LG DR275 Recorder
I have got an lg dv-275 dvd recorder, when i bought it was ewerithing ok, but now cant play nothing, do you know what is the problem? thx
Try getting a laser lens cleaner, you are supposed to clean your lens every 10 hours of use, also, listen to see if you hear the motor spinning when you insert a disk, if you can't, well, you know.
Jul 09, 2009 | LG DR275 Recorder
Lg dvd recorder dr275 initializing problems
replace dvd loader assy or mpeg pcb.
Jul 01, 2009 | LG DR275 Recorder
Cannot initialise disk LG DR275
it is either the laser(lens) or the mpeg printed circuit board. its easiest to replace the dvd loader , and to obtain one, you may need to contact LG and find their closest authorised dealer, they normally retail from $50 to $70 and depends when your model was made depends on availability. good luck.
May 18, 2009 | LG DR275 Recorder
May 09, 2009 | LG DR275 Recorder
Lg dr275 does not recagnize any disk
This can be as simple as a dirty lens or more drastic like defecitve optics. If you can access the lens, try cleaning it using a cotton swab and alcohol. Next try playing a music CD. If the CD willplay OK, but hte DVD will not, then the optics are failing and will need to be replaced.
Keep us posted.
Dan
Feb 18, 2009 | LG DR275 Recorder
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
