Error code f08 appears on my wm602 - Washing Machines
3 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Error code F08
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
It means you should try to unplug the machine for three minutes and then plug it back in and restart it! If this fails you will need to call service for error codes!!
Sounds like you need both knob and screw!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
blueextc3221
  • 15935 Answers
SOURCE: FLASHING F08 ERROR
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
F08 error code
F08 error code: Door open when program started
May 01, 2015 | Bosch Washing Machines
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Error F08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Jun 15, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Reset error code F08 in a whirlpool washing machine, or whats the problem.
May 28, 2011 | Washing Machines
Fo8
F08 error code for Hotpoint washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
I hope this help to solve it; remember to rate this answer. Nice weekend.
Oct 02, 2010 | Washing Machines
Whirpool washer F08 error code
Feb 02, 2010 | Washing Machines
F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint is showing error f08
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
Sir, I hope this helps.
Sep 17, 2009 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
