Question about RCA D61W20 61" Rear Projection Television
Focus leads for D61W20 Rca 61" Tv
After taking flyback out of tv ,and pulling focus leads out of flyback transformer how long should you strip the casing on those wiresHow much bare wire should be showing to re-insert back into flyback ?
R.R.2455
  • RCA Master
  • 5,138 Answers
Just enough to have wire sticking out reinstall in FBT.
Posted on Feb 10, 2009
I've replaced cp150 cp120 cp114 capacitors and now it turns on for about 2 - 3 min and then turns off what else could it be? rca d61w20
It could be the flyback transformer or several other items all on the deflection board. Were any of the caps you replaced domed up on top?
Jun 18, 2011 | RCA D61W20 61" Rear Projection Television
Tv help
How long have you owned the set and how long have you been having this problem? How long does the light turn on for? It sounds like its shutting down because of a malfunction could be the power board. with some more info I can assist you further.
Thanks,
Lee
Aug 09, 2008 | RCA D61W20 61" Rear Projection Television
I have a rca tv made july 2004, model d61w20 that was given to me by a friend who said it won't turn on so she just bought a new tv,from what she tells me and from what I found on the internet it has to do...
go to www.tvrepairworld.com and then click on the contact us button and list the model and symptoms. They are RCA experts and it wont cost even a fracton of that amount to figure out whats causing the problem.
Nov 04, 2010 | RCA D61W20 61" Rear Projection Television
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
May 08, 2009 | RCA D61W20 61" Rear Projection Television
Focus leads for Flyback transformer
Just use cutters to cut off small rubber part leave wire sticking out put in FBT.
Jan 18, 2009 | RCA D61W20 61" Rear Projection Television
The tv does not work
yes flyback and yoke and h.o.t all should be replaced.
repair shop was right.
Jan 09, 2009 | RCA D61W20 61" Rear Projection Television
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
Tv makes a loud "screaming" noise.
from what you descirbe this is an idication of a faulty flyback. the flyback is a special high voltage transformer that generates high voltage for the picture tubes. when you replace this you ussally replace horizontal output transistor. THis repair usally run 125 to 300 at our shop.
Jul 31, 2008 | RCA D61W20 61" Rear Projection Television
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
