Question about Frigidaire Dishwashers
My frigidaire dishwasher model FDB520RH50 wont shut off.
My dishwasher will run continuously till you stop it by openning the door.
SOURCE: squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Posted on Dec 10, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
  • 228 Answers
SOURCE: Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Posted on Aug 05, 2009
  • 534 Answers
SOURCE: Have problem with door on Frigidaire Electolux
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Posted on Feb 04, 2010
THE LATCH IS READING THAT THE DOOR IS CLOSED BUT I CAN OPEN THE DOOR WHILE THE DISHWASHER IS IN CYCLE. WITH THE SPRING INDISE THE DOOR BEING LOCKED IT WONT EVENT LET ME FULLY SHUT THE DOOR! ANY HELP.
Hello friend, thank you for your post!
From what you have described the spring from the latch is broken inside of the door and you are unable to close your Frigidaire dishwasher. You would need to disassemble the dishwasher in order to replace the latch or spring. This needs to be done by a professional technician as improper disassembly could results in personal injury. I hope this information is helpful to you. -Matt
Feb 19, 2016 | Frigidaire Dishwashers
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Frigidaire FFB240 dishwasher won't stop
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire FFBD2406NS Built In Dishwashers
My FDB2810Ldc1 dishwasher won't stop going thru the cycles. We have to open the door to stop it. When the door is closed again it starts and will continue for hours if the door is not opened again.
The first thing I would try, is to to reset the washer by unplgging it with the door open. You can do this by manually pulling the plug or by tripping the breaker that goes to that plug.
Hope this works for you,
RSMITH972278
P.S. IF YOU NEED FURTHER HELP CONTACT ME !
P.P.S. PLEASE RATE ME !
Oct 21, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Water keeps running into dishwasher
It looks like your inlet water valve is stuck after it powers on which means you have to replace it. If you can provide me a model and serial number of the dishwasher, I can provide you with the correct part number and a breakdown diagram. You can find the model number on the door frame of the dishwasher.
Post it back
techgirl26
Sep 13, 2008 | Frigidaire Dishwashers
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut ...it continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
My dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Aug 03, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Dishwashers Logo
37 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
