Question about IBM Lenovo ThinkPad T61 Notebook
My lenovo t61 screen is cloudy white
My Lenovo t61 will boot up but the screen is a solid cloudy white. I can attach a separate monitor and boot up just fine, and use the laptop. Is this problem a hardware or software issue and if so which one, and can it be fixed? Or am I into a new LCD?
    New Friend:
  • 3 Answers
Definitely hardware sounds like yo have a disconnected LCD cable or most likely its a bad lcd screen
Posted on Apr 21, 2013
Geekman
  • 32281 Answers
SOURCE: lenovo t61 laptop has no tcpip communication ran
A couple of things need to be done.
Install SP3 this is the latest service pack for XP.
Install the TCP/IP (Internet protocol)
Open Control Panel - Network Connections - right click on Local Area Connection - click on the box for Internet Protocol (TCP/IP) and the click on Install.
Then reboot the computer.
You network should now work.
Posted on Nov 29, 2009
  • 1481 Answers
SOURCE: usb ports don't work
did u disable the USB port in Device manager, if so then enable it and check if there is any yellow ? or ! mark in it
Posted on Feb 04, 2010
  • 91 Answers
SOURCE: Long continuous beep on a t61 while in windows not
Check if the system is overheating.
You can try to clean the cooling vents using a can of compressed air or a vacuum cleaner (make sure to turn off the system and disconnect battery and charger before you try this).
If the processor heatsink/fan assembly is clogged with dusts, it can cause this problem.
You need to make sure that the processor heatsink/ fan assembly is clean of any dusts.
The following link will give some idea about how to clean the heat sink
http://www.laptoprepair101.com/laptop/2006/01/04/toshiba-laptop-overheating/
(it is for a different make/ model, but the principles will be same.)
Posted on Mar 10, 2010
  • 10406 Answers
SOURCE: ibm lenovo t61 won't boot. if it overheated, is my
Yes, it's highly-likely that all your "data" files on the disk-drive are intact. Any qualified computer-technician can remove the disk-drive, temporarily connect it as a "slave" drive in a computer, and copy all your files onto DVD-writable disk(s).
Posted on Jul 20, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hello, I have a Lenovo T61 Thinkpad and am having
Hi cmbenton1...
Go to the following webpage, they may have just what you need.
Please take time to rate me
http://filespart.com/r/recovery-disc-lenovo-t61.html
Posted on Sep 01, 2011
Base system device
Hello tilakbhanari,
What are you looking for on the Lenovo T61? Does it not boot up? Is the screen blank? We will need some more information to attempt to assist you. Please post back later what the problem with you unit is and any other information that you care to send to us. Thanks
Nov 26, 2013 | Lenovo ThinkPad T61 Notebook
Lenovo t510 white screen on power up
if you have access to an external screen, attach it via the VGA port and restart the PC, if it comes up then you have a faulty inverter. Carry the machine to a recognized tech to replace inverter. Worse case scenario, you may have a faulty board.
Nov 11, 2013 | IBM Lenovo ThinkPad T61 Notebook
White line on LCD on lenovo t61
Is it there before it gets into windows? If so then it's the screen. You can probably find a replacement on ebay. If not then it's probably the video card. In this case you'll have to replace the motherboard.
Oct 30, 2012 | Computers & Internet
What does 4 beep codes mean from a Lenovo T61 that does not boot up?
Four cycles of four short beeps and a blank screen...
System board (Security chip)
Jul 14, 2011 | Lenovo ThinkPad T61 Notebook
How do I brighten the monitor on my lenovo T61?
I believe the T61 is like my T60.
The "Home" and "End" keys will act to brighten or dim the screen when you hit them as you hold down the "Ctrl" key.
Dec 20, 2010 | Lenovo ThinkPad T61 Notebook
Ibm lenovo t61 won't boot. if it overheated, is my
Jul 20, 2010 | IBM Lenovo ThinkPad T61 Notebook
Blank screen on Thinkpad Lenovo T61, when I connect a monitor and reboot it shows scramble.. help
Your video card adapter might be damage. Or you have installed a wrong driver for your laptop.
Another cause of the problem is your RAM or memory might be damage. I suggest you buy a new memory to test it.
Thanks. Cheers!
Apr 21, 2010 | Lenovo ThinkPad T61 Notebook
Blue screen on Lenovo t61 laptop
check first the program or operating system.
re instal if needed
Sep 12, 2009 | Lenovo ThinkPad T61 Notebook
Open Questions:
See all IBM Lenovo ThinkPad T61 Notebook Questions
IBM Lenovo ThinkPad T61 Notebook Logo
323 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
