Dead
SOURCE: Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
SOURCE: RE: Kenwood KDC BT945U My deck
Hi Dennis,
One of persons I know had the same problem, now all you need to do is reset the player and hopefully it would be fine , please follow the below instructions :-
You would find one reset button on the front panel, to be precise It's located between the forward button and the "1" button.
All you need to do is insert a pen and press that button and make sure that the unit is turned on at that time,
Then you will find that the unit will do blank or dark for some seconds and then back on
Also remember to always press the eject button before if you remove your USB drive as it would flash remove signal , this is a safety norm that you need to follow.
Hope this helps ...:)
SOURCE: Hello, my battery went dead
Try checking all of your fuses. There is also a fuse behind the radio itself.
SOURCE: I just put my old
take the blue/white wire coming from the radio and tie that in with your solid blue wire coming from the radio and which is connected to whichever wire in the car. So in total you'll have 3 wires at a connector.
