Question about GE DBXR463GD Gas Dryer
DRYER TUMBLES BUT WILL NOT HEAT
Model GE DBXR463GD2CC
less than 3 years old
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Posted on Jan 18, 2009
The dryer tumbles but does not heat. There is no
If you dry a lot, you may need heating coils. Heavy loads such as jeans and towels will put a premature stress on those coils.
Jun 21, 2010 | KitchenAid KEYS750LQ Electric Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My kenmore dryer modle # 9758920 tumbles but won't
ther is heat fuse on the fan unit and the heat unit check them and then you good :)...take power off first!!!
Dec 31, 2009 | Whirlpool LER5636P Electric Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
GE DBXR463GD Gas Dryer Logo
165 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
