Question about Kenmore 63942 Dryer
Kenmore dryer won't turn on
It dried one load..the second load nothing..no sound no movement..nothing..what should i check?
  • 5,911 Answers
There are several possibilites that may cause a dryer to fail. The following link will give you some pointers on where to begin:
http://www.fixya.com/support/r385301-thorough_dryer_advice
If the dryer does not run at all, most commonly this is caused by a blown THERMAL FUSE. The fuse will be located on the blower fan housing inside the dryer. Please provide me with your complete model number (located around the door opening), so that I may be able to determine how your dryer is constructed. Not all dryers are made the same and the heating circuits and fuses are located in different places. I hope this initial information is helpful to you. Let me know.
Posted on Jan 18, 2009
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 90 dryer will not start
http://www.pcappliancerepair.com/cgi...2519&brand=WPL depending on model it sounds as if it is the thermal fuse, the cabinet will have to be opened , some are in back...either way you must unplug the dryer Safety First.. :)
Feb 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryers
Check the breakers, then the wiring in the back. Make sure the wiring is connected good. Then the hi limit switch which is probably located under the top. (easy to remove).
Jan 18, 2009 | Kenmore 63942 Dryer
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
