Question about Sony RDR-VX555
Not recording our sony rdrvx555
We haven't used our unit for awhile. We are following the directions, but no light goes on to show that it's transferring from the vcr to dvd. It doesn't work when we push the vcr botton to record. It plays vcrs and dvds fine though.
SOURCE: DVD recorder has stopped recording
Make sure the DVD-R is 8x or SLOWER. They are difficult to find these days. The unit will not not give any specific warning when a faster disc is used, it just doesn't work. The burner is simply an IDE drive, so it is upgradeable, should you wish to risk that route.
Posted on Jun 16, 2007
Grubhead
  • 5309 Answers
SOURCE: I 'Finalized' the DVD but cannot play on another player
Does the machine record on to + or - DVDR?
If it does both try each type. Also try high quality discs, some of the cheaper types won't work. Try it on different speeds too.
Posted on Jun 20, 2009
SOURCE: After recording the DVD player, wont play on any other player
You need to "finalize" the dvd you created - usually on the machine that you created it on. The SONY RDR-VX525 finishes recording, then you have to go to the system menu and follow the prompts to do the "finalize". As it's finalizing, it should the word finalize on the front panel display. It'll run about a minute or two and then just stop without telling you what it did. It should be ready to play on any dvd player.
Posted on Jul 22, 2009
  • 69 Answers
SOURCE: Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Posted on Apr 07, 2010
SOURCE: My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Posted on Apr 21, 2010
Disc won't record
Try other disks If same results the dvd unit is fubar.
Sep 12, 2017 | Magnavox ZV457MG9 MP3 Player
Video goes green and extremely jumpy around lighted objects
Sam,
Is the green color apparent in the recording if played back on something other that the camcorder? If it's simply there in viewer (ccd) then you might want to know that Sony is more than aware of ccd problems with that unit and there is an active recall on that cam.
You can call Sony at 1-866-703-7669 and if they determine that the ccd is the problem they will even send you a prepaid shipping lable...
If the color variation is also there in the recording - played back on something other than the camcorder - then the optic sensor, logic board or something else is the culprit.
Bill
Nov 09, 2007 | Sony Handycam DCR-TRV38 Mini DV Digital...
Just replaced the lamp and the tv still will not power on. The green standby light just blinks and double clicks. No red light
HI:
Make sure you replace the lamp door or the unit will not power on. Also make sure the lamp is seated properly, Most people when they replace the lamp they try to turn on the television with out replacing the cover and think there is a problem with the set, there is a safety switch on the lamp cover door that need to be closed in order for the unit to operate.
Also you can check the self diagnostic mode, to see if any faults exsists.
With power off, using the original remote press the display key followed by the number 5 key, followed by the volume down key then hit power. You have to do all four keys within 5 secs for the diagnostic screen to come up. If all goes well check the number recorded on the right, should indicated lamp cover has been removed and if you had a bad lamp it is will record the a number of times the unit tried to light the lamp but failed. To exit press the 8 key then enter to reset them numbers to zero and do process over again and try to turn on tv normally, if it shuts down then go back to diagnostics screen and see what the tv recorder as error.
Nov 09, 2010 | Sony KDS-60A2000 60" HDTV
Dvd eject problem
The drawer on a dvd player is a rack and gear drive. Sounds like you may have a bad motor or a jammed drawer. If you take it a part, see if you can find the motor that drives the drawer. It should have a worm gear on it. Try to turn it to release the drawer. It maybe out of time or slipped a tooth on the gear, hope this helps
Oct 20, 2009 | Sony Televison & Video
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS to DVD dubbing
YOUR OWNERS MANUAL
Please follow the troubleshooting steps found on page 105 of the user manual.
Additionally, be sure all cables are hooked up properly (page 12)
Thank you for using FixYa - a FixYa rating is appreciated!!
Feb 08, 2009 | Sony RDR-VX555
Does not record
Have you selected the correct input? These recorders are desinged to stop after 20 seconds of silence. Do you get any level showing on the record level meters? Press the source button until it shows 'analogue' if recording to the 2 phono inputs.
Dec 29, 2007 | Philips CDR770 CD Recorder
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Nov 09, 2007 | JVC DRM10 DVD Recorder
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Open Questions:
See all Sony RDR-VX555 Questions
Sony RDR-VX555 Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
