Printer problems the printer stiops printing before the print is complete & the the cartridge sticks wherever it stops. what are the 3 buttons on the printer for 1 LH button has a cross onit 2 centre button, looks klike it should feed the pages, it also makes a test page 3 RH button, light flashes none of the buttons do anything at this time
  • 2,692 Answers
Reinstall printer. Make sure that you install disk is for the version of windows that you have. If you do not have the disk go on the support website for you brand printer and download the software and an updated driver. You may als get an instruction manual for the same site
Posted on Jan 18, 2009
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Actually for a HP deskjet 990cxi
1. Turn on the HP DeskJet.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
1. Press and hold Cancel .
2. While holding Cancel , press On .
3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
4. Press Cancel again.
5. Press Copies .
6. Press Paper Type .
7. Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
4. When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
5. Reconnect the USB cable.
Jun 03, 2008 | HP DeskJet 940c InkJet Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp deskjet f380
I have experienced this before...
Disconnect the printer and remove the installed drivers, that is to remove the virus-infected file or a corrupt printer driver.
Now re-install the printer and the driver.
Fixya me on this one...
Feb 08, 2008 | HP DeskJet F380 All-In-One Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Sqeaky paper feed the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
35 people viewed this question
