Question about LG WM-2277HW Front Load Washer
Pre soak Is there a way to pre soak in this model?
Yes. In the top left is a button you can press to pre-soak. It's the some one for child lock. You just hold it down longer is you want the child lock on.
Posted on Jul 25, 2007
Bleach soak
hi my name is charlie lapinski. I will be helping you with your problem.
can i have the complite model number?
Mar 29, 2014 | Whirlpool Washing Machines
I have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
I have purchased model #20050611. Can I smoke with wood chunks only and not use charcoal? Do I put the pre-soaked wood in the flame disk bowl or the water bowl? I am used to a double barrel wood smoker...
Wood only. No Charcoal. If you're using wood chips - soak them first. No sure wood chunks will work, as they will have a tendency to flare up & burn rather than smoke.
The presoaked wood chips go in the flame disc bowl, below the water bowl. The water bowl goes on the first shelf bracket from the bottom up.
I was going to send you a copy of your Owners Manual, but the Model Number you listed does not match up with any Masterbuilt Smokers?
Enjoy your smoker,
Apr 21, 2011 | Masterbuilt 20050106 Propane Smoker
How can I remove a striped edged noxygen sensor
if the edges are rounded off and socket or wrench slip try small pipe wrench or vice grips pre soak with penetrate oil
Mar 08, 2010 | 2001 Nissan Sentra
Where do you put the wood chips, and do you pre-soak the chips?
yes you pre-soak wood chips. use a nice bed of charcoal to get the fire going when coals get to smoldering in the very bottom try you start adding wood chips. Smoking is an art. you need patience lots of it. its called cold smoking. Do not put the chips in dripping of water, shake off excess water and put them directly on the coals. evry so often add a few dry chip, but only if you think your losing to much heat. I have smoked deer meat and fish and beef for that matter for as long as seven days. Just be sure to kep water in the second pan.
Feb 14, 2010 | Masterbuilt 20050106 Propane Smoker
How do you soak clothes in Whirlpool Duet
front loaders don't have a soak cycle because of the very little water that they use.
use the pre-wash setting to extend the time.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I can't figure out how to pre-soak clothes
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 16, 2009 | Kenmore Washing Machines
LG WM-2277HW Front Load Washer Logo
157 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
