Question about Garden
Gas went in head old snowflite snowblower for sidewalks why?
  • 755 Answers
Carb is dumping! Get a service kit with a new float, needle and seat and install. Can be done with basic tools and mechanical abilities. You can look up the carb type online for specific instructions.
Posted on Jan 26, 2013
Poulan snowblower won't start; it backfires and sometimes starts but only lasts a few minutes if lucky; I've replaced spark plug and gas.....no luck
Gotta take the Bowl off the carburetor and see if the Jet is Plugged up.
Today's Ethanol gas ills carburetors. New gas wont help a gummed up carb from leftover old gas.
Dec 30, 2013 | Poulan Snowblower 205cc 8.0 TP Briggs OHV...
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
Gas leak from valve to pool heater
Leak is probably at a connection, unless pipe is ruptured.
Use soap and put soapy water over each connection and look for bubbles in the soap.
If gas line was put in after sidewalk was poured, then there will not be a connection under sidewalk.
Buy gas detector, but cheap one may not work well especially in wind.
Apr 05, 2013 | Pool & Spa
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Snowflite 12/30 manual
Hello Darrick, So you have a snow flite by M T D that is canada made model # 311951500, have been all over the web and can't find a manual for a 12 hp 30' CUT,you are going to have to contact a snowflite dealer for this,when you find the manual please let me know where you find one so i can pass this on to other customers,thank you,
Jan 29, 2012 | Tecumseh Snowblower Snow Blower Starter...
Broke the chain , on snowblower
top idler sprocket was out of alignment,staitened plate it was attached to, then chain was running true and went on just fine. it was an old wheel horse snowblower.
Dec 15, 2009 | Garden
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
