Question about RCA D61W20 61" Rear Projection Television
Focus leads for Flyback transformer
I have one question since You had mostly posted what I need to fix my RCA D61W20.I unsoldered flyback and have it ou.Had a heck of a time w/ focus leads ,but they are off.
Now alls I need to know to re-install flyback is how much actual wire is suppose to be exposed ?When I pulled out of old flyback had just under a 1/4 of an inch exposed,but don't know if part of it might have snapped off inside flyback.TIA.
RR2455
  • tboz70 Mar 05, 2009
    The previous post was similar to mine, but I cant seem to get the wires out of the flyback at all! Is there something I'm not doing right, or am I just not pulling hard enough? I don't want to cause further damage, but I can't get the thing disconnected. HELP! :)
  • RCA Master
  • 5,138 Answers
Just use cutters to cut off small rubber part leave wire sticking out put in FBT.
Posted on Feb 10, 2009
I've replaced cp150 cp120 cp114 capacitors and now it turns on for about 2 - 3 min and then turns off what else could it be? rca d61w20
It could be the flyback transformer or several other items all on the deflection board. Were any of the caps you replaced domed up on top?
Jun 18, 2011 | RCA D61W20 61" Rear Projection Television
Can you provide the steps to replace the flyback transformer on a Sony Trinitron model KV-32S40?
Replacing the flyback is the most dangerous part to replace on CRT sets, because of the high voltage lead that plugs into the tube needs to be unplugged. the tube will hold 20,000v+ at any given time.
If you are OK with this then what you need first is a Flat head screwdriver and a alligator clip. clip one side of the clip to the ground that goes around the tube (silver wire wrapped around tube) then the other end on the metal part of the screwdriver. Now slide the screw driver under the rubber cap on the top of the tube and lift so you can the the lead under the rubber, the touch it with the screwdriver to discharge the tube, now unplug it by wiggling it from left to right as your pulling. Now only 2 more wires. the other wires go to the crt board, one may be soldered in, you just need to unsolder it. the other wire will be inside the white cap on the crt board. there well be a lever thing that goes up or down right by the wire, move it and it will release the wire. Plug all wires back in from new flyback
Now you must unsolder the old flyback and solder the new one in. after that is done turn the set on. dont be worried if no picture, Sonys need to be adjusted sometimes. try turning the knob on the flyback (the one on the bottom). try to get it right in the middle, and set should come on, then adjust for brightness and focus (top knob)
Aug 27, 2010 | Televison & Video
RCA FLYBACK
Hello: The first thing is optaining the exact replacement part. Next there are approixmately 12 pins on the bottom of the deflection board where the part is located that need to be unsoldered there is a slightly thick red wire coming from the top of it that goes into the splitter block and a thin red one that goes to the focus Block, each need to be removed. To get to the focus block the lower front cover of your television needs to be removed Reverse the procedure to install the flyback transformer. You may want to purchase a soldering iron and some solder wick, commonly known as desoldering braid from radio shack.
Please leave comment...Thx
Aug 30, 2009 | RCA HD56W66 56" HDTV
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
Focus leads for D61W20 Rca 61" Tv
Just enough to have wire sticking out reinstall in FBT.
Jan 18, 2009 | RCA D61W20 61" Rear Projection Television
Flyback
I read the other post you made and I don't belive that the flyback transformer has gone , and these models and makes from rca do have some common fixes that are found out by tech's . this problem that you are having can be in the power section , stanby circuit , protection circuit or even a horizontal output IC or some component that is causing the set not to come on . the flyback transformer would need to be tested to determine if it went bad but the power section would need to be tested first because there are different voltages that come out of the primary transformer and they go to different parts of the tv's functions and circuits , also info like what happen when it went out? and or was there a problem with it while watching it before it went out? , this can help to know what section was failing , thus start the testing in that section.
the best thing to do is to call an electronic repair shop to have a teck come out so they can determine the failure for you , as these are pretty complex sets and unsoldering and soldering , testing of and value idenentification of components is required , so if you cannot perform these then you could be putting alot of money into it and never finding the problem.
if you would like any more info , I'll bee glad to assist you
Dec 07, 2008 | RCA P52960 52" Rear Projection Television
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
Transformer 271996
IHVT or flyback transformer has 3 leads = high voltage to CRT,
focus and screen leads to small circuit board on end of CRT.
.................T.
May 26, 2008 | RCA 32V420T 32" TV
TV WILL NOT TURN ON
Check for solder cracks around the flyback and around the line coil next to the flyback. If that doesnt help go to this link as you will most likely need a flyback they have them and offer free assistance.
http://servicemanuals.vstore.ca/
May 11, 2008 | RCA D61W20 61" Rear Projection Television
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
