Question about Levelone ServCon WPS-9122 (WPS9122) Print Server
Level One WPS-9122 Print Server not functioning
I am not able to get my Epson CX6600 All-In-One USB printer to work with the Level One WPS-9122 Print Server. I have loaded the software and using the installed utilities I can locate the printer router/server. After using Windows to add a printer, I cannot get the printer to print the test document or any other document.
Problem not solved.
All help oprovided did not help to solve the problem.
I am returning the print server to the seller.
I would like a refund of the $9.99 I paid for the Premium service.
Posted on Jan 19, 2009
All print jobs stay in queue
I recently installed CUPS. At first everything looked good, the server started and i was able to add printers with the browser or KDE-Control center.
I tried to add an Epson Stylus C86, which is connected at my USB Port. It really looked good too, cups automatically found the printer on the usb-port and suggested the right driver. I added it, configured it and tried to print a test page.
The job was added correctly in the queue but nothing happened. it was just pending there.
I took a look at the error log but there wasnt anything suspicious, so i set the logging level to debug and tried again. After reading through that (now very long) log again, i still wasnt able to find anything false or any error.
Im a bit clueless now, no errors, smooth install and no signs of anything wrong. OR
If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I am having problems with setting up my printer (Epson TX710W) to run remotely from my router. When I attempt to setup the router it wants me to use it for internet connection but I am running my internet...
Hi Robert_fl657,
For any printer to run on the network (wired or wiireless), aside from just a router, you will need a print server. Now, since this printer has wireless capabilities, i am going to assume that you might have a wireless prinet server built in (WPS). If your wireless router does not have that function, i suggest you buy a wireless print server to accomodate the printer that you would want to hook up.
Possible Solution 1: Sync wireless printer with WPS button on wireless router
1. Try and locate the WPS button (if any) on the wireless router.
2. Once located, go to the network options on the wireless printer and select set up by WPS.
3. Once you have selected that option, the printer should be in a seeking mode. Select and hold the WPS Button down on the wireless router.
4. If all goes well, you should have established connectivity with the wireless router.
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Apr 04, 2010 | NetGear DG834G Router
Can't print from computer
Hello. the best way to get going again is to hook up the USB cable between your printer and computer and then run your printer driver disk. If you do not have the printer driver disk, you can download it for free. Just google Epson Stylus CX6600 printer driver
Feb 12, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Does a Level1 WPS-9122 print server work with Windows 7?
Yes, You can purchase WPS-9122 and use on Windows 7. Though the seach utility comes with WPS-9122 may be out of date, in another word it might not be compatible with Windows 7 since WPS-9122 came out long before WIndows 7.
For your reference, most of the networking equipments are OS independent. For example, printer server, router, switch. The version or type of OS does not effect it;s usage.
LevelOne Technical Support
Jan 18, 2010 | Computers & Internet
Unable to use Memory Card with PC VISTA
The scanning software for your printer must be installed separately from the printer software on Vista systems. The following link will take you to the page to download the scanning software....just find your model number and select it:
May 03, 2009 | Office Equipment & Supplies
Level One Print Server not serving
Hi Mr Giles,
If you click on your Network icon in the bottom right hand corner of your Vista Desktop, and click Network and Sharing Center, is Printer sharing enabled?
Chris (ziraffa)
Jan 18, 2009 | Levelone ServCon WPS-9122 (WPS9122) Print...
Does not find a print server
Don't know for sure what the problem is, but I would try hooking the printer to the computer with a USB cable and then see if the print server "sees" it. Usually then you can unhook it, put the lan cable back on, and the print server will find it. Or, sometimes I have clicked on the printer properties, then searched till I found the IP address. Then manually put the IP address in where it asks for it under "add network printer". By the way, my print server hooked up to the router, and to make it work the first time I had to plug my printer into it. Then I was able to unplug it, and use it normally.
Jan 02, 2018 | Levelone ServCon WPS-9122 (WPS9122) Print...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Levelone ServCon WPS-9122 (WPS9122) Print Server Logo
295 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
