Question about KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator
What's your problem?We have a Kitchenaid refrigerator model KBRA20EMSS. It has ice on the floor of the freezer that continues to get thicker. Please advise. Thanks so much!
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
  • 306 Answers
SOURCE: ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Posted on Jan 11, 2009
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
SOURCE: Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Posted on Jan 18, 2010
  • 4793 Answers
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Posted on Mar 06, 2010
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
Can i change the door swing on my kitchenaid KBRA20ERSS?
HI,
This model was design to be reversible, I would look in the uses and care booklet or installation manual for the instruction to reverse your door. It will only take about 30 mins or less to do the job. I would empty the door, then remove the door to make is easier, from the screws on top of the door.
Good Luck
Oct 08, 2011 | KitchenAid Architect KBRA20EMSS Bottom...
Ice maker has stopped making ice. We've cleared cubes stuck in the rack. Now it does not work at all.
HI,
What position are the harvest finger in currently? The ice harvest fingers should be in the 2 o'clock position in the normal run mode. Also is the ice collection bin in place, some models have a switch to detect if bin is missing it will not allow the production of ice to continue.
I hope this helps..
Jul 23, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
The water to the icemaker just keeps flowing
It sounds like your solinode valve has stuck open and may need to be replaced. the valve is located in the back of the refrigerator on the bottom. follow the water line to it. shut off the water supply to the refrigerator unit unit is repaired.
Dec 20, 2010 | KitchenAid Architect KBRA20EMSS Bottom...
Ice maker continualy runs even when ice tray is full
theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
Jan 10, 2009 | KitchenAid Architect KBRA20EMSS Bottom...
KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
